Txt-Dxf export - for scene 7.0
SAttaya
Full Name: Steve Attaya
Company Details: Geocent
Post by SAttaya » Wed Sep 13, 2017 1:24 pm
The manual I have is Txt-Dxf export - Revision 01 – 23 Oct 2015
Will there be a version for 7.0?
Oliver Buerkler
Full Name: Oliver Buerkler
Skype Name: oliver_buerkler
Re: Txt-Dxf export - for scene 7.0
Post by Oliver Buerkler » Tue Sep 19, 2017 2:28 pm
Hi Steve.
SCENE 7 is offering DXF export as well.
Best regards,
Oliver Bürkler
Oliver Bürkler
FARO Europe GmbH & Co. KG
oliver.buerkler@faro.com
Twitter: FARO_LS_PM
SAttaya
Post by SAttaya » Tue Sep 19, 2017 10:39 pm
Oliver,
We use it to export one line per target sphere with:
* scan name
* sphere/target name
* X
* Y
* Z
and then crunch those in SA or Excel.
(would like to get distance
Well, I just tried it with 7.0.2.5 and it seems to work at least with the
parameters I tried on a project with one scan and 6 auto found targets.
Does anyone know why it's not in the Faro AppCenter any more?
Oliver Buerkler
Post by Oliver Buerkler » Wed Sep 20, 2017 4:56 pm
Hi Steve.
We seem to imagine different things. I was refering to the DXF export from SCENE.
I am not sure if I understand correctly what your question is referring to.
Best regards,
Oliver Bürkler
Oliver Bürkler
Twitter: FARO_LS_PM
Tgl_Nan
Full Name: Yan Koch
Company Details: TagLabs
Post by Tgl_Nan » Wed Sep 20, 2017 8:55 pm
This is probably our export plugin. We are changing the brand name currently, this is why it has been removed from the store.
This plugin was available for free. It should still work on Scene 7.xx.
It should be available again soon. However, here's a link to download it:
https://we.tl/1oYRqUQT25
Yan Koch
yankoch@taglabs.fr
SAttaya
Post by SAttaya » Thu Sep 21, 2017 5:20 pm
Yan - Thanks - it does seem to work as I said in a later post.
Oliver,
basically we'd like to analyze targeting/registration data out of Scene.
Things like get individual RMS's for a registration and know which target(s)
is contributing to the greatest error.
Ability to change weight of target based on distance and fit, etc.
remove target from one registration (anti-correspondence) and
get new RMS with stats for other targets being updated.
Distance is obviously one of the factors that would want to make you
weigh an individual scan more or less.
Goodness of fit the same thing at approx same distance (actually a band
from the scanner, or maybe even a function of the distance to the target
from the scanner and the target(s)).
getting the scanner locations and the target properties (# points, distance,
position dev, scan point dist
scan point drift, xyz, radius deviation, method (faro auto or manually selected, etc).
just my 2¢s.
Oliver Buerkler
Post by Oliver Buerkler » Fri Sep 22, 2017 2:40 pm
Hi Steve and all.
The updated Apps of Yan Koch are now available at the 3D App Center.
https://3d-apps.faro-europe.com/
Search for "TagLabs" to see them all.
Thumbnail Screenshots by Thumbshots
Best regards,
Oliver Bürkler
Oliver Bürkler
Twitter: FARO_LS_PM
Return to “FARO SCENE”
