Scene 7 OrthoPhoto
Jana-at-kubit
Full Name: Jana Siebenbrodt
Company Details: FARO Technologie Inc [Dresden]
Company Position Title: Platform Owner
Re: Scene 7 OrthoPhoto
Post by Jana-at-kubit » Fri Aug 04, 2017 6:20 am
William,
Can you describe the problem in more detail please?
AutoCAD 2017 should be able to open the DXF.
What exactly does not work?
Do you get any error message or is it that you just cannot see the image?
Jana Siebenbrodt
http://faro.com/
Jana-at-kubit
Post by Jana-at-kubit » Fri Aug 04, 2017 6:44 am
Hi Chris,
I made a Test with SCENE 7.0.0.39.
I've produced an ORTHO as TiF. When I open it in Paint.Net the background is transparent:
Also if I import the DXF with the TiF to AutoCAD my image has a transparent background.
Which software are you using for post-processing the Orthos?
Jana Siebenbrodt
http://faro.com/
Jana-at-kubit
Post by Jana-at-kubit » Fri Aug 04, 2017 6:58 am
Hi William,
I was able to open an Ortho.DXF created with SCENE in AutoCAD 2017.
I made a short video to show you the steps: https://faro.box.com/s/i9hnvt2asy2oe1hsobzhxmb7r8gvuv3q
Hope this helps.
Jana Siebenbrodt
http://faro.com/
Wannascan
Full Name: William Hart Rabbino
Company Details: Kestrel Construction
Company Position Title: Co-Owner
Post by Wannascan » Tue Aug 08, 2017 4:51 pm
Thanks when I get a chance I will try again.
Oxbow
Full Name: Eric Bergholz
Company Position Title: CEO
Skype Name: eboxbow
Post by Oxbow » Tue Aug 15, 2017 11:44 am
maybe you check pointcab software out. PointCab generate automaticly dxf ortho image. It is easy to open in AutoCad, 1 click it is done.
http://www.pointcab-software.com/en/
..Eric
Wannascan
Post by Wannascan » Tue Aug 15, 2017 6:17 pm
I followed your instructions but it is still coming in with incorrect dimensions. The orthophoto app was one of the best things about scene it is amazing that FARO would ruin their app so it would work with "other drafting software" Tailoring to anything except autodesk products is a mistake
WWilford
Full Name: Warren Wilford
Company Position Title: owner
Post by WWilford » Tue Aug 15, 2017 9:59 pm
I was running into the problem of the ortho photos not being the correct size when attaching the tif file into AutoCAD in full scale as was the workflow that I have always used. The same export settings in Scene was leading to different size ortho photos by a large margin. I found that if I use the dxf export option in 2D I can open the dxf file in AutoCAD with the photo attached at the correct scale. Hopefully they get this fixed quickly, I have customers that use Vectorworks with the ortho photo in tif form bering their preferred option.
Scott
Full Name: Scott Page
Post by Scott » Tue Aug 15, 2017 10:08 pm
Having a useful scale bar (and reference dimension) embedded within the orthophoto, helps with scale issues in CAD.
Jana-at-kubit
Post by Jana-at-kubit » Wed Aug 16, 2017 6:28 am
Hi William,
I am sorry that you are still having issues getting the ortho image into AutoCAD at the correct scale. I understand your frustration.
Our developers are investigating the issue. It looks like it is related with imperial units. We will try to fix this as soon as possible.
Jana Siebenbrodt
http://faro.com/
Jana-at-kubit
Post by Jana-at-kubit » Wed Aug 16, 2017 6:46 am
Hi Warren,
I am glad you were able to import the ortho image at the correct scale by using the DXF.
We will check what the problem is with loading the TiF file directly without using the DXF.
It possible to import/open DXF files with Vectorwoks tool?
Does Vectorworks show the image when opening the DXF?
Thanks for your feedback. It helps us improve.
Jana Siebenbrodt
http://faro.com/
Return to “FARO SCENE”
