fix scans coordinates
Emanuele
Full Name: Emanuele Ferrari
Company Details: Studio FERRARI
Company Position Title: Titolare
Country: Italia
Post by Emanuele »
I am doing some registration tests and I would like to try to simulate this situation.
I know the precise position of each scan (for example through external GPS) and I have acquired the compass data; Is it possible to automatically assign and fix the coordinates of each scan and record using the rotation given by the compass?
Thank
max72
Full Name: Massimo De Marchi
Skype Name: massimo_de_marchi
Re: fix scans coordinates
Post by max72 »
I did it getting GPS coordinates of the scan position AND spheres.
I wouldn't rely on compass.
viewtopic.php?t=5618&start=40
Emanuele
Country: Italia
Post by Emanuele »
max72 wrote:
Wed Apr 08, 2020 4:18 pm
I thank you for the answer.
I understand that the use of the compass is not ideal but I am doing some tests to check the "minimum" settings to get to the alignment of the scans anyway.
With only two scans set, the compass doesn't help!
With two scans fixed and a common point the alignment works but I get an error message that I don't understand!!
Return to “FARO SCENE”
