Hi everybody,
After many coffee mugs, we are proud to announce the release of our 2 new packages:
A- Improved filter package:
Edge filter:
We managed to optimize its speed and efficiency. The edge filter is now a stray points killer. It also removes the points that are too shiny. You probably noticed that some points create a white flash. This occurs when the laser beam is closed to 90° with shiny surfaces such as stainless steel pipes. Our filter now combines the edge + high reflectance points removal.
Improved plane filter: you can create custom planes using our Extended toolbox plugin. You can use it to clean all the bad points captured through double glazing.
And: uniform filter, angular filter, circular / pipe filter (useful for tanks), points removal according to the project axis.
B- Extended toolbox:
12 features to make you save time.
- Object properties manager,
- Clipping box manager: align (axis, 2 points, plane, pipe), change size, move, rotate, translate,
- Sphere remover: removes the "bad" spheres using criteria,
- Create pipes with standard diameters,
- Create custom planes using 3 or more points, create horizontal planes using 1 point and vertical planes using 2 points,
- Create circles, arc of circles, using 2,3 or more points
- Create custom spheres
- Create outlines,
- Create intersection between: 2 planes (line), 3 planes (point), a pipe and a plane,
- Project cleaner
- Txt / Dxf exporter: all the objects can be exported,
- Orientation and origins: quickly change the orientation of your scans / cluster / project
Please feel free to PM or to send me an e-mail at [email protected] . I'll send you a free trial.
The plugins should also be available on the Faro App center soon.
New Scene plugins release
- Full Name: Scan ku kaï
- Company Details: Scankukai
- Company Position Title: CEO
- Country: France
- Has thanked: 58 times
- Been thanked: 207 times
- Country: France
Re: New Scene plugins release
Here are 2 small videos I just uploaded:
- edge filter + shiny points:
youtu.be/S_xljwgE27U
- clipping box manager:
youtu.be/BDw009lxOzM
- Country: France
Hello everybody,
Our plugins are now on the Faro App Center.
You can also visit our website: https://www.taglabs-solutions.com/
Here's also the link to the website of the mobile tool that we will release soon: https://www.kiptag.com/photo-annotation-home
- sreed
- Full Name: Scott Reed
- Company Details: Prologue Systems
- Company Position Title: Principal
- Skype Name: sabotva
- Has thanked: 16 times
- Been thanked: 15 times
Congratulations Yan. These are excellent enhancements to Scene and we'll be sure to upgrade given your long track record of creating valuable Apps for Scene.
I look forward to continuing to work with TagLabs (Liber-D),
-S.
-S.
