Cleaned Points Still Show Up In Exported E57s
c2a
4
Full Name: Corey Weiner
Company Details: C2A Studio
Company Position Title: Founder
Has thanked: 9 times
Post by c2a »
I've noticed after meticulously cleaning points (both visual and cloud-to-cloud) in Register 360, they still get exported in E57 format (like this example). However, the same problem does not happen when exported as a unified RCS.
I've checked the preferences and we are set to export only cleaned E57s. Also, the files contain only some of the deleted points (like these trees).
Anyone know what this can be?
c2a
4
Re: Cleaned Points Still Show Up In Exported E57s
Post by c2a »
Still, no one else has this problem?
SCarbo
4
Full Name: Samm Carbo
Company Details: Major Power Company
Company Position Title: Geospatial Engineer
Country: US
Has thanked: 3 times
Post by SCarbo »
I just submitted a support ticket to Leica for this same problem but with an RCP.
We do not have this issue with projects that have zero limit boxes saved. And with projects that do have limit boxes saved and ready for export when exporting the RCP files by limit box the the projects come out cleaned.
We did all kinds of trouble shooting to resolve the issue, so waiting to hear back from Leica after they get my data set.
Carbix
Full Name: Daniel Loney
Has thanked: 33 times
Been thanked: 53 times
Post by Carbix »
Did they get back to you?
Daniel Loney - Owner
Excelsior Measuring inc.
www.ExcelsiorLevel.com
c2a
4
Post by c2a »
I guess no one has heard from Leica on this? It still happens.
I don't think hit has anything to do with saved limit boxes since we never save them.
Carbix
Post by Carbix »
I'm still running into it and it seems to be some kind of memory issue. Now my computer is strong enough.
Iv recently cleaned and exported 2 different reports and had 2 different outcomes. 1 where the data was clean and another using the exact same process exported with the junk data.
I also recently had a project where I went back in and restored all the points and cleaned them out and it worked... So something is not remembering to keep the points cleaned on export. Keep in mind it's non-destructively removing the points, the software is only ignoring the points.
Iv noticed that if you export and LGSx first the rest of your exports are junk...
Has thanked: 785 times
Been thanked: 158 times
Post by gsisman »
c2a wrote: Fri Nov 10, 2023 11:41 am I've noticed after meticulously cleaning points (both visual and cloud-to-cloud) in Register 360, they still get exported in E57 format (like this example). However, the same problem does not happen when exported as a unified RCS.
Make sure you deleted both visible and cloud to cloud points. (in setup view or Bundle view) There are two different "flags set" in the DB -one to not use points for cloud to cloud and one for not visible-exportable points.
I think when you "clean points" in the Registration Align setups or view link tool, which you do in order to get good/better registrations, you are NOT cleaning the visible points, but only the Cloud to cloud usage. Someone can correct me if I'm wrong
c2a
4
Post by c2a »
This happens after cleaning points (both visual and cloud-to-cloud). Both boxes are checked.
I then export two formats at the same time, a unified RCS and individual E57s. In most cases the RCS looks nice and clean but the E57s still show the cleaned points. This is despite both formats being executed in the same batch.
It is definitely a software bug that I would have hoped Leica would fix by now.
Post by gsisman »
c2a wrote: Fri May 17, 2024 8:20 pm This happens after cleaning points (both visual and cloud-to-cloud). Both boxes are checked.
I'll have to check mine. Is it either type of E5 export7?, both individual setups and/or As one large file? Are you decimating it any on export?
c2a
4
Post by c2a »
I am just exporting two file types: individual E57s and unified RCS. There are no changes to any other settings and there is no decimation. The cleaned points that show up on the export do not appear on the screen when the project is open.
