Batch archive via CLI
ajcpdv
4
Full Name: Arron Craig
Company Details: PDV
Country: New Zealand
Post by ajcpdv »
I have a number of projects I would like to archive but doing each one via the GUI is very time consuming.
Is there a way to do this in batches through the GUI or preferably via a CLI?
badam
2
Full Name: Adam Berta
Country: Hungary
Has thanked: 36 times
Been thanked: 221 times
Re: Batch archive via CLI
Post by badam »
What kind of archive do you want to do, and why?
Fast archive is just a copy of the project in the project storage folder.
Do you want to delete it rom the menu or just free up space? If the latter then just move the given projects's folders via file explorer.
Kruse
1
Full Name: Kruse
Company Details: HPCC
Company Position Title: Lead VDC Engineer
Has thanked: 30 times
Been thanked: 70 times
Post by Kruse »
ajcpdv wrote: Tue Mar 28, 2023 2:45 am I have a number of projects I would like to archive but doing each one via the GUI is very time consuming.
Within your Projects & Storage tab, you can multi select all the projects you want to archive and batch archive them with either the fast or standard archive methods. Just hold control while selecting all the projects you want to archive. Like Adam said, the fast archive just copies all the project files and dumps them to your archive location. A standard project archive will combine and compress all the project files to a single .RAF file to your archive folder location. When using the fast archive, it's up to your SSD's speed to determine how fast those will transfer (but won't compress the overall project size to save space downstream). When using standard archive, it will compress/move them anywhere from 30MB/s to 65MB/s, depending on your CPU. I think it's 85% to 90% of the size of the originial project database within Reg360 as well. You could probably archive and transfer ~1TB overnight if you have that many projects available. I've always started the archive before I went home for the day and not once was it still archiving when I got back to the office in the morning. I think the most I've ever done at once was around ~500GB.
ajcpdv
4
Post by ajcpdv »
Kruse wrote: Tue Mar 28, 2023 3:47 pm
Brilliant, Thankyou. Will give that a shot.
