Hi All,
i have some doubts about Register 360 and add sitemap function.
I wuold to use additional sitemap to cut big bundle in different bundle of limitated scope area.
When i move the setups in new sitemap seems that sitemas lose the original orientation?
Someone have the same issue?
Thanks a lot
New sitemap orientation - Register 360
- Full Name: CAMPANA PAOLO
- Company Details: Smartargets Srl
- Company Position Title: Bim Coordinator
- Country: Italia
- Full Name: Adam Berta
- Country: Hungary
- Has thanked: 51 times
- Been thanked: 297 times
Re: New sitemap orientation - Register 360
it is just what you see. If the bundle is the same then your cloud will be aligned correctly by the links across sitemaps. If you have two bundle then they will not be on the same coordinate system no matter if those are in the same location on a sitemap.
If you want it to stay the same orientation you can move/rotate the accordingly. it will not change the registrations.
- Full Name: Tristan Thibault
- Company Details: BBA
- Company Position Title: Coordonnateur en technologies relevés 3D
- Been thanked: 5 times
when you create your UCS, it link to one scan. take this scan and move it to your new site map end register will make it availeble in this site map. You can apply it and your orientation will look good. move it back to his original site map and all your different site map will look with the same orientation.
