Register 360 Bug when zooming in once scans are imported
nathanpro
Full Name: Nathan
Company Details: Construction
Company Position Title: Virtual Design
Has thanked: 10 times
Post by nathanpro »
When zooming in on the individual scans after importing, to visually align, the white preview of the scan disappears once you zoom in too far... see images. This only happens every once in awhile and I cannot seem to figure out what causes it... Does anyone know the fix to this? Could be import settings that I used...
badam
Full Name: Adam Berta
Country: Hungary
Has thanked: 52 times
Been thanked: 297 times
Re: Register 360 Bug when zooming in once scans are imported
Post by badam »
be my guest for issues like this...
https://laserscanningforum.com/forum/vi ... hp?t=17916
small workaround press z or zoom fit button from the menu bar if this happens...
nathanpro
Full Name: Nathan
Post by nathanpro »
Weird... That did the trick! Thank you!
nathanpro
Full Name: Nathan
Post by nathanpro »
Hello again, I have seem to run into the same issue, but this time the cloud preview for individual scans is visible but dissapears when I add it to my large bundle. I tried using the zoom command/Z button and it does not fix the issue this time. Any ideas? See attached image.
