Export PTG from R360
- JLarson
- Full Name: Jason Larson
- Company Details: VHB
- Country: US
- Been thanked: 25 times
Quick question: I have an R360 project that has both RTC360 and BLK2GO data registered together in a single bundle. I would like to export the RTC data to PTG for use in Edgewise. When I go to Publish the PTG option is greyed out. My guess is that this is because there is unstructured BLK2GO data in the DB. I moved the BLK2GO scans to a separate SiteMap (still part of the Bundle), but the PTG option is still greyed out. Am I missing something?
Jason Larson, PLS
- smacl
- Has thanked: 627 times
- Been thanked: 657 times
Re: Export PTG from R360
Do you have a publisher license? Many export formats will be greyed out in this case.
- JLarson
- Country: US
Yes, Publisher, but not Publisher Pro. Not sure if they moved PTG over to the Pro version or not (wouldn't think so).
Jason Larson, PLS
- Full Name: Adam Berta
- Country: Hungary
- Has thanked: 51 times
- Been thanked: 297 times
I heard that (never came across because lack of interests in 2go) you can export structured clouds only if you already has a finelazied registration when there is a 2go walk...JLarson wrote: ↑Tue Nov 30, 2021 4:23 pm Quick question: I have an R360 project that has both RTC360 and BLK2GO data registered together in a single bundle. I would like to export the RTC data to PTG for use in Edgewise. When I go to Publish the PTG option is greyed out. My guess is that this is because there is unstructured BLK2GO data in the DB. I moved the BLK2GO scans to a separate SiteMap (still part of the Bundle), but the PTG option is still greyed out. Am I missing something?
I just don't understand why can't they just made it available to export separatelly in one go.
The best would be "export separated structured e57" option and if there is a blk2go walk, then export it as unstructured and structured the tls setups...and every walks should go in their own separated e57...
let the user do whatever he/she wants with it. Without data loss (reference which points was in which walk.)
- I have made 30-40 posts
- Full Name: Daniel Jansson
- Company Details: Teodoliten Mätteknik AB
- Company Position Title: Reality Capture Consultant
- Country: Sweden
- Has thanked: 7 times
- Been thanked: 6 times
Might be obvious but I ask anyway to rule out stuff. When you moved it to a separate sitemap, in the finalize step, did you only select the sitemap with RTC data and uncheck the blk2go sitemap?
