using the same coordinate system
jensen.a07
4
Full Name: Aaron Jensen
Company Details: LDI
Company Position Title: 3D Scanning Specialist
Post by jensen.a07 »
i m having trouble copying the coordinate system from one project to another in cyclone 9.4. i have the exterior of a building i need to copy the coordinate system from so it will line up with the interior when i send the data off to get modeled separately. i have heard of a way of exporting the coordinate system from one and importing it into another but i can remember how. i think it had something to do with a .txt file.
i need the coordinate system from church 1 copied and imported to church in
Fresh
8
Full Name: Fresh
Company Details: AFC
Company Position Title: Land-Engineering Surveyor
Re: using the same coordinate system
Post by Fresh »
It depends how the site survey has been carried out in order to make the registration.
But if you mean that you have your site control currently in church 1 and you have surveyed some of that control in the scans in "church in" you can select the vertex in your control controlspace in "church 1" - file - export as .txt , define the columns to Point ID - E - N -EL when prompted and import this file directly in "church in". It Will be a scanworld that you can use for the registration then.
