i m having trouble copying the coordinate system from one project to another in cyclone 9.4. i have the exterior of a building i need to copy the coordinate system from so it will line up with the interior when i send the data off to get modeled separately. i have heard of a way of exporting the coordinate system from one and importing it into another but i can remember how. i think it had something to do with a .txt file.
i need the coordinate system from church 1 copied and imported to church in
using the same coordinate system
- Full Name: Aaron Jensen
- Company Details: LDI
- Company Position Title: 3D Scanning Specialist
- Full Name: Fresh
- Company Details: AFC
- Company Position Title: Land-Engineering Surveyor
Re: using the same coordinate system
It depends how the site survey has been carried out in order to make the registration.
But if you mean that you have your site control currently in church 1 and you have surveyed some of that control in the scans in "church in" you can select the vertex in your control controlspace in "church 1" - file - export as .txt , define the columns to Point ID - E - N -EL when prompted and import this file directly in "church in". It Will be a scanworld that you can use for the registration then.
