Yes data is from RTC360 FW4.0.badam wrote: ↑Thu Jun 17, 2021 2:37 pmThese are not very good numbers, where are the sources are kept during import, just to sort it out try to copy the source files to-from the source and project directory in windows explorer and see how fast it can read/write...daniel.jansson wrote: ↑Thu Jun 17, 2021 10:08 am These 2 steps are by far the biggest culprits during import:
Import::ReadAllImageData, 20.3, GB, 33, GB, 245, seconds
HandleMainScanData::BuildScene, 15.6, GB, 38.6, GB, 733, seconds
this is from nas to nas. Is your data come from RTC360 FW4.0? if it is not confidential, if you send them i can try to import that.Code: Select all
############################### RTC360: Job 214- stp002 Import time 235.381 Seconds total Note, Used, GB, Available, GB, Delta, Seconds Import::Initialize, 4.31, GB, 50.4, GB, 0.015, seconds Import::ReadAllImageData, 9.67, GB, 48, GB, 71.5, seconds HandleMainScanData::ReadScanInfo, 9.82, GB, 47.8, GB, 7.72, seconds HandleMainScanData::WriteArchiveFile, 9.85, GB, 47.8, GB, 1.6, seconds HandleMainScanData::BuildScene, 11, GB, 46.7, GB, 140, seconds HandleMainScanData::ScrubScanDataPoints, 11, GB, 46.7, GB, 0.025, seconds HandleMainScanData::Create Thumbnail, 11, GB, 46.7, GB, 2.29, seconds HandleMainScanData::Rotate Points, 11, GB, 46.7, GB, 0.0686, seconds HandleMainScanData::ProcessScanPoints, 11.1, GB, 46.5, GB, 1.9, seconds HandleMainScanData::CreateCubemapsForWayPoint, 11.8, GB, 45.9, GB, 3.01, seconds HandleMainScanData::ColorizePoints, 11.9, GB, 45.8, GB, 0.293, seconds HandleMainScanData::WriteToPointCloud, 12.1, GB, 45.6, GB, 2.37, seconds HandleAllSubScanData::Done, 11.9, GB, 45.8, GB, 0.029, seconds Import::FinalizePointCloud, 11.6, GB, 46.1, GB, 3.51, seconds Done, 4.36, GB, 53.3, GB, 0.749, seconds ###############################
I have two internal 2Tb NVMe m2 SSD drives. 1 with windows, software installations and temp folder. The other with project storage and raw data where I import from. It doesn't really matter if I place the raw data on the first or second drive though.
Those numbers that you are showing are basically what I had on the 2020 version with the same setup. I will see if I have something I could send.
