Reading the Reg360 help file it says you can link across sitemaps (e.g. difrferent floors of a building, linked as one bundle but across different sitemaps for exporting or ease of working out which scans are on which floor.
How do you link setups / bundles between sitemaps?
Linking across Sitemaps
- formbysurveys
- I have made 90-100 posts
- Full Name: Andy Roberts
- Company Details: Formby Surveys Ltd
- Skype Name: formbysurveys
- Has thanked: 6 times
- Carbix
- Full Name: Daniel Loney
- Has thanked: 33 times
- Been thanked: 50 times
Re: Linking across Sitemaps
Have a bundle in each site. Take a setup from one group and move it to the other side (make sure it's linked). Once the setup from the old site is in its new site you can link it to a setup in the new site. once done you can move that setup back to its point of origin.
- formbysurveys
Thanks Daniel - I've got the first bit to work i.e. dragging a linked setup into the 2nd sitemap and linbking it there - now I want to move it back as per your post but dragging it between sitemaps wont work if the sitemap isn't visible on the view on the left - I click and drag the linked scan but cant add it back to the original sitemap as I can't scroll down to drop it into the sitemap due to the number of scans.
What am I doing wrong?
Andy
Andy Roberts
Formby Surveys Ltd
Andy Roberts
Formby Surveys Ltd
- KlausR
- I have made 50-60 posts
- Full Name: Klaus Rieke
- Company Details: Multivista
- Company Position Title: Reality Capture Manager
- Been thanked: 12 times
Hi Andy,
I suggest to minimise the Sitemaps, so that you can only the see name of the Sitemap rather the bundles, setups
- formbysurveys
Thanks Klaus but you can’t then select a setup as it’s minimised within its bundle
Andy
Andy Roberts
Formby Surveys Ltd
Andy Roberts
Formby Surveys Ltd
- Full Name: James Elson
- Company Details: SCCS
- Company Position Title: HDS Support
- Been thanked: 24 times
Hi Andy,
If you create a new sitemap and then select the scans that you can see from the sitemap you want to move setups back to.
Then drag and drop them onto new sitemap. You maybe need to do this once or twice more depending on how many setups you have.
Now you should be able to move the scan/s back to sitemap.
Then to return the moved setups, minimise all the sitemaps apart from the new one and drag and drop them back.
Regards
James
Regards
James
- formbysurveys
Thanks James that seems like a logical solution to the problem - not sure why it has to be as complicated as that though
Andy
Andy Roberts
Formby Surveys Ltd
Andy Roberts
Formby Surveys Ltd
