Leica CloudWorx 2020.0.1 & New CloudWorx for Bentley
CloudWorx 2020.0.1 for AutoCAD
CloudWorx 2020.0.1 for Revit
CloudWorx 2020.0.1 for Navisworks
CloudWorx 2020.0.1 for PDMS
CloudWorx for 2020.0.1 for BricsCAD
CloudWorx for Bentley is an upgrade of the former CloudWorx for MicroStation product with new, added host application support. The 2020.0.1 release of the plug-in expands support of Bentley’s MicroStation to include Bentley’s AECOsim Building Designer and the new OpenBuildings Designer.
https://myworld.leica-geosystems.com/irj/portal
- LeicaUK_RC
- Full Name: Phil Marsh
- Skype Name: Phil.H.Marsh
- Been thanked: 52 times
- I have made 80-90 posts
- Full Name: Marco Dileo
- Company Details: ARcontrol
- Country: Italy
- Has thanked: 32 times
- Been thanked: 12 times
Re: Leica CloudWorx 2020.0.1 & New CloudWorx for Bentley
Very nice, finally AutoCAD 2021 support!
Even if they added multiple LGS opening, there's still one big bug/missing feature to solve: you can't send a .cwprj+lgs to a collegue, the .cwprj file won't find the (new) .lgs file path and there's no way to modify it. This is very very limiting, and I'm quite exausted to report it.
- gsisman
- Full Name: Steve Long
- Skype Name: gsisman1
- Has thanked: 767 times
- Been thanked: 149 times
I think the CWPRJ file contains an absolute path to the LGS file, so if the LGS file is in an identical path (i.e. C:\SCANS\JETSTREAM PORTABLE) on both the original machine and the Colleagues machine it will pull it up. I may be wrong, but this is how we ensure that all CIVIL 3d Projects and other items with external links or pointers can reconnect when we carry projects to other local Workstations. It also may be true that the cwprj file is keyed to the actual ACAD/Civil DWG it was originated in. This is not the case with Jetstream Enterprise I believe.markscan wrote: ↑Fri Jun 19, 2020 6:58 pm Very nice, finally AutoCAD 2021 support!
- Country: Italy
I just think it's something they really have to fix quickly. It's called Cloudworx 2020, but seems a software released in 2002.gsisman wrote: ↑Sat Jun 20, 2020 3:15 amI think the CWPRJ file contains an absolute path to the LGS file, so if the LGS file is in an identical path (i.e. C:\SCANS\JETSTREAM PORTABLE) on both the original machine and the Colleagues machine it will pull it up. I may be wrong, but this is how we ensure that all CIVIL 3d Projects and other items with external links or pointers can reconnect when we carry projects to other local Workstations. It also may be true that the cwprj file is keyed to the actual ACAD/Civil DWG it was originated in. This is not the case with Jetstream Enterprise I believe.markscan wrote: ↑Fri Jun 19, 2020 6:58 pm Very nice, finally AutoCAD 2021 support!
Not to mention the fact that you can't link an ongoing Reg360 project to Cloudworx (the "old" MS Import), you need to compress and export a .lgs first.
- Full Name: Duy Nguyen
- Company Details: Baezeni VietNam
- Company Position Title: Baezeni VietNam
- Country: Vietnam
- Skype Name: duy_bz
- Has thanked: 8 times
- Been thanked: 8 times
Can you upload link download for Revit? i haven't account Leica Thanks
- LeicaUK_RC
http://sccssurvey.co.uk/techsupport/?dir=HDS/Cloudworx
I would recommend creating a free Leica MyWorld account as you have access to lots of things including, products, service, support, learning, trusted services and downloads.
https://portext.leica-geosystems.com/zlgs/wda/register
- Jason Warren
- Administrator
- Full Name: Jason Warren
- Skype Name: jason_warren
- Has thanked: 443 times
- Been thanked: 246 times
Hi Phil,
Do you have a directory for previous versions e.g. CloudWorx for AutoCAD v6.4.2.0 ?
Co_Founder
LaserScanningForum
Co_Founder
LaserScanningForum
- Phil Marsh
- Administrator
- Skype Name: phil.h.marsh
- Has thanked: 119 times
- Been thanked: 36 times
We have limited space on that ftp server so we have to archive superseded software to a different drive.
What version are you after and I'll send a link?
