Can't publish a .lgs
sim.herrod
I have made 100> posts
Full Name: Simeon Herrod
Company Position Title: Scan and CAD Tech
Has thanked: 9 times
Been thanked: 8 times
Post by sim.herrod »
For the first time ever, I've had to use a provided e57 to create a Cyclone 9.4 database/project as I want to use the published .lgs in Cloudworx.
I've configured a database and imported the e57, and can see everything in the modelspace.
I know you need to be in ortho/top view to publish the .lgs but I keep getting the error message saying:
'Publishing to LGS File requires the viewer to be in orthographic mode and the viewing directon to be top-down'
I am and it is, but it still won't publish. I'm probably missing something simple, but does anyone have any ideas?
Yuelin
I have made 80-90 posts
Full Name: Yuelin
Been thanked: 6 times
Re: Can't publish a .lgs
Post by Yuelin »
Please try this work-around: go to the View menu -> Set up Direction to Y, then set the up Direction to Z. then try to publish again.
sim.herrod
Yuelin, tried that and it will now publish, but when I open the lgs with Cloudworx in AutoCAD, it has messed up the coordinate system.
The modelspace in Cyclone shows the correct Ordnance Survey coords, but in AutoCAD the lgs is wrong.
What I forgot to try is to 'Open MS View', and that is working fine.
Obviously not as good to work with as JS or lgs, but at least I can get on with my drawing.
Thank you for trying to help.
elsonj
Full Name: James Elson
Company Details: SCCS
Company Position Title: HDS Support
Post by elsonj »
Hello ,
Check that the UCS is set to Default or i found if you click the left mouse button and pull down/drag mouse towards you on the modelspace it overcome the issue as well.
Regards
James
sim.herrod
elsonj wrote:
Fri May 29, 2020 8:31 pm
Check that the UCS is set to Default...
That worked, thank you James.
Now shows correct OS coords in JS Viewer and loads correctly into AutoCAD.
Is that a bug when importing an e57 into Cyclone as I've never had to do that in JS Viewer before?
