Cyclone PTS file Import - Largest file
mickharris71
Full Name: Michael Harris
Company Details: Seam Surveys
Skype Name: mickonbribie
Post by mickharris71 »
Hi All
I have exported a 300GB PTS file from Cyclone 2020 to upload via FTP to a modeller. They said they cant import PTS files larger than 90 GB. Obviously I can break it into smaller sections, but was wondering if this is correct? How can cyclone not import a file it has exported?
Phil Marsh
Full Name: Phil Marsh
Skype Name: phil.h.marsh
Has thanked: 26 times
Been thanked: 11 times
Re: Cyclone PTS file Import - Largest file
Post by Phil Marsh »
If it’s cyclone to cyclone why not use an LGS file or JetStream?
LASER SCANNING FORUM
Yuelin
I have made 80-90 posts
Full Name: Yuelin
Been thanked: 6 times
Post by Yuelin »
Why not use .imp file directly? No export and import is needed.
gsisman
Full Name: Steve Long
Skype Name: gsisman1
Has thanked: 125 times
Been thanked: 31 times
Post by gsisman »
mickharris71 wrote:
Fri May 22, 2020 9:35 pm
Hi All
I assume because you are exporting .PTS that the modeller is NOT using Leica Product?
mike annear
Full Name: Mike Annear
Company Details: Mike Annear
Has thanked: 4 times
Been thanked: 19 times
Post by mike annear »
One way to get your large point-cloud into a Modelling package is to chop it into usable chunks.
In the past I have used a rectangular array of Limit boxes, in Cyclone, to accurately slice a large point cloud (of an entire Oil Rig) into manageable pieces.
The array is pretty easy to set up in the Limit box manager, and it can also be saved for later use.
You then switch the limit boxes on one at a time and export the contents. Each piece stays in the correct place relative to the others.
I found this related video.
https://www.youtube.com/watch?v=d6F4Pn0MZm4
Export each chunk as an E.57 (not Pts) if you want more manageable files.
I don't have Cyclone in front of me, I have mocked up what your clipping cubes should look like.
Mike
www.mikeannear.com
