I'm really struggling at finding how to undo a point deletion in Cyclone Register... A CTRL-Z tool, something allowing me to go one step back if I delete some points by mistake without having to restore all the points I've already deleted and start from scratch...
I've found something in the manual, see the attached image, but my version of Cyclone doesn't have the restore tool... I'm running the 1.6.2...
Any help?
Cyclone Register 360 - Undo CTRL Z restore deleted point step back last action
- I have made 50-60 posts
- Full Name: Gianni Epinotto
- Company Details: GC CM
- Has thanked: 9 times
- Been thanked: 9 times
- Full Name: joe smetanko
- Company Details: wd partners
- Company Position Title: Senior Manager Field Services
- Country: usa
Re: Cyclone Register 360 - Undo CTRL Z restore deleted point step back last action
As far as I know .... There is not any "undo" functionality in Register 360. If point data, Scans, Images are accidentally deleted the raw data must be restored or re-imported.
Bad programming!
Bad programming!
Joe Smetanko
Sr. Manager, Field Services
D +1 614 634 7277 | M +1 614 698 8491
- I have made 30-40 posts
- Full Name: Corey Weiner
- Company Details: C2A Studio
A Leica product expert confirmed there is no "undo" button. I wish there was and hope they add it.
- landmeterbeuckx
- Full Name: Lieven Beuckx
- Country: Belgium
- Has thanked: 183 times
- Been thanked: 548 times
Lot's of pointcloud softwares don't have an undo button : Riscan, Pointcab, Scene also i think (you can go back to a previous saved state). Looks to me it's dificult to program.
- gsisman
- Full Name: Steve Long
- Skype Name: gsisman1
- Has thanked: 767 times
- Been thanked: 149 times
I think you can restore cleaned points between two linked scan stations without having to restore all the points in the bundle. You can also just restore the C2C points without restoring the visible points you have cleaned out. By my guess what the DB does is flag a check in the DB to remove it for C2C or for visible or for both. You can right click on each setup and restore the points you want from that setup...fpensa wrote: ↑Fri May 01, 2020 1:19 am Hi,
Any help?
