I recently scanned a project with a Leica P40, and there were a total of 46 scans. All of these scans are show up in the registration as leveled, however, when using visual alignment to apply cloud constraints some appear to be not leveled. When using the visual alignment to apply cloud constraints between some of the first and last scans it is visually obvious that one scan is tilted compared to the other. What is odd, however, is that this tilt disappears when viewing the scans in anything other than the visual constraint view. For instance, viewing the interim results between the first and last scan produces a view where neither scan is tilted relative to each other. The error shown for the cloud constraints between the first and last scans is significantly higher than all the other errors, and I believe this due to the fact that one shows up tilted when visually aligning them. Is there anything I could have done while scanning or registering that could have caused something like this?
Edit: Only the last 3 scans show up tilted in the visual alignment. I did turn the scanner off and then back on again right before performing the last 3 scans. The last 3 scans do NOT appear tilted when trying to visually align them among themselves.
Cyclone level error/Visual alignment
- Full Name: Joshua Bretscher
- Company Details: Universe Corporation
- Company Position Title: Project Modeler
- I have made 50-60 posts
- Full Name: Matthias S
- Company Details: TPI
- Company Position Title: 3D-Team Coordinator
- Has thanked: 13 times
- Been thanked: 6 times
Re: Cyclone level error/Visual alignment
Is the scan itself tilted somehow? You can check for the "seam" or overlap in each scan at 0° and 180°. If you go into truespace and look on the floor, it is easy to see a thin area, where the point cloud is more dense. Check for elevation deviations in a distance of 5 to 10 meters in the overlapping area.
Just checked and there is a slight variation at the seam (~0.05"). This is roughly what it is for a few of the scans I checked that are not tilted. It is just odd to me that the last 3 scans only appear tilted in the visual alignment window. Registered in a modelspace they do not appear tilted. Is there anything coordinate system/origin wise I could have accidentally changed? (Also edited original statement to say that the 3 scans do NOT appear tilted relative to each other in the visual alignment window)
- Full Name: James Worrell
- Has thanked: 14 times
- Been thanked: 87 times
Double checking - are they nominated as "[Levelled]" in the scan list? This obviously locks the scan horizontally. If the compensator was turned off and the scan is not set as levelled it will be allowed to tilt in the cloud-to-cloud.
Yes, all scans I'm trying to register have the "[Levelled]" after their name in the scan list.jamesworrell wrote: ↑Mon Apr 06, 2020 9:29 pm Double checking - are they nominated as "[Levelled]" in the scan list? This obviously locks the scan horizontally. If the compensator was turned off and the scan is not set as levelled it will be allowed to tilt in the cloud-to-cloud.
