Register 360 1.6 Limit Box Weirdness
mstachoni
Full Name: Matt Stachoni
Company Details: Tutor Perini Corporation
Post by mstachoni » Mon Jun 17, 2019 4:20 pm
Anyone else having issues with Reg360's Limit Boxes?
Sometimes they work fine - I can use the mouse to navigate in the orbit mode just fine, and select a limit box face or edge and adjust its size or rotation as usual. Other times Reg360 simply isn't determining that I'm over a limit box face and will only orbit. I have to exit the program and get back in for limit boxes to function as they should.
It's almost like there is a mode that needs to be toggled on or off that signals when the mouse is over a limit box face to change the mouse behavior from orbit / navigate to modify the limit box.
- Matt
geomontgomery
I have made 90-100 posts
Full Name: George Montgomery
Company Details: ECE Design
Has thanked: 10 times
Been thanked: 6 times
Re: Register 360 1.6 Limit Box Weirdness
Post by geomontgomery » Mon Jun 17, 2019 4:25 pm
Are you using CTRL + left mouse to toggle orbit while in limit box mode?
mstachoni
Post by mstachoni » Mon Jun 17, 2019 4:48 pm
That's the problem - there is no "limit box mode" activated and CTRL doesn't toggle anything. It just stays in orbit mode and I cannot affect the limit box at all.
Once I exit the project and get back in, I usually can activate a limit box and have it work - in that case CTRL will toggle between orbit and toucha-da limit-box mode. Then after a while the limit box mode decides not to work.
- Matt
geomontgomery
Post by geomontgomery » Mon Jun 17, 2019 4:52 pm
Can you try hitting "R" or "O" to swap between orbit and orbit orthographic? Then try to manipulate the limit box.
edit: I think I was able to reproduce the bug but maybe not in the same way you are. If you alt-tab away from the window while the limit box is active, this "breaks" the ability to toggle the faces on the limit box when you alt-tab back. I was able to workaround this by deactivating then activating the box again. Maybe something you can also try as well.
It also appears that "alt" will allow to modify the pitch/yaw/rotation of the limit box
mstachoni
Post by mstachoni » Mon Jun 17, 2019 5:03 pm
Nope, 'r' and 'o' toggle perspective on and off as usual, but nothing works to activate limit box edting mode - even though the limit box is visible - besides exiting the project and getting back in. I do not have to completely exit Reg360 though.
- Matt
jsteinert
Full Name: joshua steinert
Company Details: pb2 architecture + engineering
Company Position Title: Graphics Manager
Has thanked: 4 times
Post by jsteinert » Wed Sep 11, 2019 10:50 pm
Thanks for the close, reopen recommendation. That seems to be the effective path to edit limit box again.
Return to “Leica Cyclone”
