Poor Performance with shaded clouds
Moc
Full Name: Matthias Korscheck
Company Details: TPI Vermessungsgesellschaft mbH
Company Position Title: Surveying Engineer
Post by Moc » Sat May 11, 2019 5:00 pm
Hey everyone,
when i turn on the "Cloud Shaded" option, my viewing performace in the the ModelSpace is going down tremendously. I guess nobody uses this option much, but since I had to import point clouds without RGB nor intensity values I need this option to be turned on.
Without this option the performance is just fine. Strange thing is, when I turn off the option, select one point so that it gets highlighted, the other point clouds get "shaded" (and a bit transparent) but my performance is still good.
Any similar experiences?
My computer has a GeForce GTX 1060, an i7 @ 3.6 and 64 Gbyte RAM.
smacl
Full Name: Shane MacLaughlin
Has thanked: 13 times
Been thanked: 12 times
Re: Poor Performance with shaded clouds
Post by smacl » Sun May 12, 2019 1:07 pm
Worth firing up task manager and seeing whether the GPU or CPU is the bottleneck. Is it a laptop or desktop as laptop versions of many chips don't give the same performance as desktop.
Moc
Post by Moc » Mon May 13, 2019 7:12 am
It is a desktop computer.
Task manager tells me, the GPU is the bottleneck. Even with a single shaded point cloud in the ModelSpace the GPU load is at 100%. Performance is fine in Recap with shaded clouds. I wonder if it is my setup or is it poor programming of shaded clouds in cyclone?
Has thanked: 22 times
Been thanked: 20 times
Post by Matt Young » Mon May 13, 2019 8:56 am
Try changing the OpenGL mode.
Press the windows button. And select All Programs/Leica Geosystems/Cyclone/Utilities/Open GL Modes
You may need to try a few to find what works best.
smacl
Post by smacl » Mon May 13, 2019 11:53 am
Could be a number of things. In addition to the OpenGL mode I'd try dropping the display resolution to get more speed. GPUs tend to bottleneck on the number of pixels they need to render per frame so if you're currently running at 2560 or 1920 pixels wide, try dropping to 1280. Could be that the style of shading the Cyclone is using is compute intensive and needs a very beefy GPU. The 1060 is at the lower end of things by today's standards.
pburrows145
Full Name: Paul Burrows
Has thanked: 8 times
Been thanked: 5 times
Post by pburrows145 » Mon May 13, 2019 2:39 pm
This mode is quite processor intensive and will result in slower performance than standard pointcloud views.
The other function you are talking about is a selection "feature" - the clouds not selected are not "shaded" by normal computation (more like a transparency filter) - hence the speed is not affected.
Check your OpenGL settings, make sure Cyclone is using the Graphics Card, ensure you're on the latest drivers etc...
Return to “Leica Cyclone”
