Hi everyone
The current workflow for exporting 1 pointcloud for each scan station (nonunified), is to select the scan world and export only the selected entity. This requires many exports, when you have many stations. Is there a more automatic way to work with this?
Export 1 pointcloud for each scanstation
- Phill
- Full Name: Phillip Nixon
- Company Details: SKM
- Has thanked: 7 times
- Been thanked: 45 times
Re: Export 1 pointcloud for each scanstation
You could try the ptx splitter on this post. Chops a big ptx into the smaller single scans. Export all your clouds at once then let the tool chop them up.
viewtopic.php?f=88&t=6040
Phill
Phill
- Full Name: James Worrell
- Has thanked: 14 times
- Been thanked: 87 times
Export all as PTG .. you get a PTG file per scan .. no doubt you will want to convert to something else.
- Phill
James is right, but because ptg is binary not many other programs will read it...even if it is smaller.
- Full Name: Suran Khani
- Company Details: SkelDK Landinspektoerer
- Country: Denmark
- Has thanked: 6 times
Thank you everyone. I am familiar with the PTX-splitter but was hoping that it could be done in Cyclone, so I don’t have to have another procedure.
I am being told that there is a script made by someone, which does the job in Cyclone. Does anyone know where to find this script?
