Hi all,
We have some problems creating the truviews created in cyclone from Faro scans.
We got the scans in FLS and we exported E57 from Faro and imported in cyclone and registered along with other Leica scans. Since we received the scans from two different scanners and need to register all together!
The problem is when we create the truviews out of this faro scans, the truview screen is complete black and just showing a red arrow while rotating/navigating.
Also we could not change the colours of the scan in edit colormap and it still showing green colour points.
Another point is we even unable to export these registered scans to E57 or PTX (even they are not unified)
Can someone help us creating the truviews out of faro scans. The scans does not have rgb values. All we need is a grey scale truviews.
Any help much appreciated.
Thank you,
Naveenvarma
FARO TO CYCLONE - TRUVIEW RELATED
- I have made 70-80 posts
- Full Name: Naveen
- Company Details: AROWANA SOFTWARE SOLUTIONS
- Company Position Title: Delivery Head
- Country: INDIA
- Skype Name: naveen.arowana
- I have made 90-100 posts
- Full Name: Yuelin
- Company Position Title: Lead software engineer
- Been thanked: 11 times
Re: FARO TO CYCLONE - TRUVIEW RELATED
Try to change color mapping from " Color" to "Intensity mapping" in the TruView publisher settings. The possible reason is your data from Faro doesn't have color.
- Full Name: Naveen
- Country: INDIA
Hi Yuelin,
I will try that. I dont think it will work since i could not change the scan colors from color map parameters (Edit object>Appearance> Edit color map)
Regarding the color, yes they don't have colors they all are B&W scans. What i need is a grey scale Truviews only and not the colored ones.
Thank you,
Naveenvarma
Thank you,
Naveenvarma
- Full Name: Yuelin
In the "Site Map Settings" dialog, click ""TruView Setings". then click "Color Mapping Settings", change to "Intensity Map" + "Grayscale", you should be able to publish TruView in grayscale.
