Registered File Formats for Aveva
billrice
Full Name: Bill Rice
Company Details: Fast Track Projects - South Af
Country: SA
Skype Name: jaffa.rice
Post by billrice »
Hi LFM,
we have scanned a column for our client. We are using a Leica HDS 6100. We use Cyclone and Recap for registration. We also use Edgewise Plant to produce CAD models. Our client has requested that we supply them with a registered pointcloud in ZFC or LFD. Whats the best workflow using what we have to give to the client using Aveva PDMS with LFM software (I believe its LFM Modeller)?
Regards Bill Rice
mobile: +27823728137
stevenramsey
Full Name: Steven Ramsey
Company Details: 4DMax
Skype Name: steven.ramsey
Has thanked: 17 times
Been thanked: 14 times
Re: Registered File Formats for Aveva
Post by stevenramsey »
If your client has LFM generator you can write the transmorations from inside Cyclone register back to the ZFS files which LFM will read as "registered ZFS" which is what a ZFC file is
Steven Ramsey
Home [email protected]
Work [email protected]
Mobile +44 7766 310 915
anonimou
Full Name: Delio Pontes
Post by anonimou »
Hi All,
Before I was using HDS7000, register in Cyclone 9.1.3 and write the transformations back to the zfs files with no problems.
From the last week I started to use a new ZF IMAGER 5010C, register in Cyclone and write the transformations again to the zfs files.
But when I import this zfs registered again to Cyclone they are in a wrong position (2, 3 meters away), only the translation is correct.(Only the first scan position have the correct transformation)
Does any know anything about this issue?
Delio Pontes
JenniC
Full Name: Jennifer Copple
Company Details: AVEVA
Company Position Title: AVEVA LFM Senior Application Consultant
Post by JenniC »
Hi Bill,
As Steven has said, if you are using Cyclone to register the scans you can write the registration information back to the header of the .zfs in Cyclone. These registered .zfs files can then be brought into LFM Server: Gateway Mode and converted to .zfc (LFM's native individual scan format). Once the scans have been converted to .zfc you can produce an LFM Server dataset (.lfd) which you client can load into PDMS via LFM Server.
If you would like further information, including license costs, you can contact our LFM Value Added Reseller (VAR) in South Africa who will be able to provide you with local support and industry knowledge in your time zone:
Horts Geo Solutions
GPS-Lands-Singapore44 Hiddingh Road,
Bergvliet, Cape Town,
7945
Email: [email protected]
Tel: +27 (0) 83 227 1823
Web: http://www.horts-solutions.com
Sales contact: Ashley Pearce ([email protected])
Jenni
LFM Software Ltd
Return to “AVEVA Suite”
