Im very new working with LFM
But I was able to import registered scans to the gateway, create the database and the netview files...
Now I want use LFM Server to check and navigate inside the 3d points cloud on the 3d view mode.
But on this view, LFM is not showing me all the points from the scanners, how I can increase the points number on the 3D view?
I know that I have all the points because using the buble view, I can see all.
LFM -How to Increase points number on the 3Dview mode?
- anonimou
- Full Name: Delio Pontes
- Company Details: Williamson Technical Services Limited
- Country: United Kingdom
- Company Details: Rio Tinto Iron Ore
- Company Position Title: Specialist Surveyor - Mine Engineering
Re: LFM -How to Increase points number on the 3Dview mode?
Try creating a new volume for the areas you're interested. This loads more points in these areas than you can see in the whole dataset. Server doesn't load all the points in the main view, there's a limit to how many points can be viewed....
- anonimou
