LFD files
naveenvarma
I have made 70-80 posts
Full Name: Naveen
Company Details: AROWANA SOFTWARE SOLUTIONS
Company Position Title: Delivery Head
Country: INDIA
Skype Name: naveen.arowana
LFD files
Post by naveenvarma » Wed Aug 12, 2015 10:40 am
Dear All,
How can i convert the registered ZFS to LFD files and which software should i purchase to generate those files.
Also i want to create the bubble views. Where can i produce them
Thank in Advance,
naveenvarma
Full Name: Naveen
Country: INDIA
Re: LFD files
Post by naveenvarma » Thu Aug 13, 2015 9:03 am
Any news?
Ryan Kilmurray
Full Name: Ryan Nicol Kilmurray
Company Details: LFM Software
Company Position Title: Application Consultant
Re: LFD files
Post by Ryan Kilmurray » Thu Aug 13, 2015 9:26 am
I have asked your LFM Value Added Reseller (KK Geosystem) to contact you in order to answer your questions and provide you with further information on this topic. They should be in contact with you soon.
Ryan
LFM Software Ltd
richard_m
Full Name: Richard Merrin
Company Details: Fugro
Country: Netherlands
Re: LFD files
Post by richard_m » Thu Aug 13, 2015 10:47 am
All the formats you mention are from Aveva LFM, you'll have to have talk with them about what modules you need for your purpose. I'm a bit shocked a company with the capability of Trigeo are not already using this..
Your .zfs files will need converting to .zfc and then LFM will work with these files to export whatever you need. An .lfd file is the LFM equivalent of a Cyclone .imp file.
Richard.
Obinna
Full Name: Egwuonwu Henry
Company Details: Ariosh Limited
Company Position Title: Design Engineer
Country: Nigeria
Re: LFD files
Post by Obinna » Thu Aug 13, 2015 11:58 am
Hi Naveenvarma.
Today is your lucky day.
Its not so much of a big deal. The format you requested is LFM software file format. Hence you have to buy LFM software to process your ZFS to LFD.
1. Data Conversion
• Export the ZFS of the processed data
• Launch LFM Advance mode on the system
• In the LFM Advance mode window, click on the LFM logo on the window and navigate to LFM Gateway.
• Right click on the untitled icon
• Navigate to New
• Click on Register group
• Rename the group
• Right click on the group and import processed data into the group
• Afterwards, the data is re-registered in the new group
Wait for the process to run to completion (Note, this process might take a while, depending on the data size been processed)
2. Second stage (Dataset creation/LFM generation)
After the registration of the data in the created group, follow the following steps to generate the usable dataset.
• Right click on the name of the group
• Navigate to "Generation setting" in the drop down menu
• Click on the "Generation setting"
• Go to generation window
• Define the dataset destination on the host system (click on select/browse, and set the destination folder)
• Return to the generation setting window, navigate to the Intermediate setting button
• Click on the intermediate setting button
• Create a folder in the D drive of the host system
• Next, click on final point in the generation setting window
• Check the volume
• Check the density to either full or half (Remember that this will affect the size of your data so use your discretion.
• If the exported data have colour, check the colour
• Click on "Generation tab" (below the menubar)
• Click on Dataset
• Save dialogue box will come up. Navigate to where you want the data set to be
• Type in the name you want the data set to be called
• Click save.
• Click ok for all dialogue boxes that will pop up afterwards (if all the requirements of the data processing that pops up is met by the system used to process the data)
I hope this helps.
If you still have issues, you can contact me through my email.
MartinK
Full Name: Martin Kerfoot
Company Details: LFM Software Ltd.
Company Position Title: Channel Manager Asia
Country: Malaysia
Re: LFD files
Post by MartinK » Thu Aug 13, 2015 2:43 pm
To create .LFD from registered .ZFS you'll need the 'LFM Dataset Generation' product. Just import the registered .ZFS, convert and compress to .ZFC (this is where the BubbleViews are created also), and produce the .LFD.
BubbleViews are integrated in every LFM product, not run in a separate application, you don't need a specific viewer.
Depending on how you're using the laser data, you can then add on Autodesk/AVEVA/Bentley/Intergraph/SIEMENS CAD links to use the point cloud in your 3D design systems.
If you want to use the BubbleViews online - take a look at LFM NetView http://web.lfm-software.com/en/Promotio ... tview.aspx
LFM can host this on the cloud using Microsoft Azure. It needs no administration by you.
Martin Kerfoot
LFM Channel Manager - Asia Pacific
Shumakandr
Full Name: Andrey Shumakov
Company Details: JSC PromServis
Company Position Title: Chief survey department
Country: Russia
Skype Name: shumakov.andrey
Re: LFD files
Post by Shumakandr » Sat Sep 10, 2016 5:19 pm
Hello.We Have a small project 44 scans.Scans are alligned and each into separate PTX.We need to convert them for
Aveva E3D,LFD format.But we have no LFM licence.Could anybody help,please contact.
Graham
Full Name: GrahamM
Company Details: AVEVA
Re: LFD files
Post by Graham » Tue Sep 13, 2016 9:39 am
Welcome to the forum Andrey.
The LFM server used in conjunction with E3D will read LFD datasets, but not generate them. To load the PTX data a standard LFM Server is required, with appropriate Gateway and Generator licenses. I have forwarded you enquiry onto AVEVA Russia and LFM Support, so hopefully someone will be making contact.
stoddy13
Full Name: Scott Todd
Company Details: Handley Surveys
Company Position Title: CAD Technicain
Re: LFD files
Post by stoddy13 » Fri Oct 14, 2016 1:45 am
Hi All,
We Currently have a large data set produced in cyclone that we are trying to convert into an .lfd database through LFM.
We initially exported PTZ files and we managed to generate a dataset successfully, albeit with some failed conversions, however the option to import colours was not available and therefore only bought through a grayscale cloud.
We are trying to generate a dataset with split ptx files, due to the size, however this managed to convert about half of the files but it failed during the dataset creation.
Has anyone had any luck converting large datasets froom cyclone into LFM and what is the best way to complete this?
Thanks for your help.
richard_m
Re: LFD files
Post by richard_m » Mon Oct 17, 2016 7:53 am
I do this a bit. You could try the following..
Copy together a set of your RAW UNEDITED (STRAIGHT-OFF-THE-SCANNER) scan files to a new disk or partition with plenty of space. In Cyclone open your finished Registration Modelspace and use tools-scanworld explorer to "write back" (save) the current parameters of your current registered scans to the raw scans you've just copied together.
This gives you a set of raw scans with their parameters updated to match those in your Cyclone Reg.
You can then import these newly updated scans into LFM Generator and batch convert them all to .zfc files, this is the "generic" scan file format of LFM. You can then use the LFM Register module to import these .zfc files into a new empty LFM registration (without changing them) and from this registration LFM Server can export you an LFM Dataset that is based upon a .lfd file in the same way that a Cyclone database is based around a .imp file.
Hope this makes sense, its a bit of a p.i.t.a. hack-around but it works for me. Mostly.
Richard.
Return to “AVEVA Suite”
