LFM Modeller + clash detection LFM VS Navisworks
mhuynh1031
Full Name: Minh Huynh
Company Details: SNC Lavalin
Post by mhuynh1031 » Fri Aug 30, 2019 12:21 am
Little background about myself: I’m a junior-ish Piping designer trying to improve myself and our workflow in our department.
Anyone familiar with the modeller software with LFM ? I looked online and according to the brochure, there doesn’t seem to be a plug in connection to plant 3D ? I’m not sure since I have never used the software.
We currently have to model existing for stress analysis. My company is trying to give our stress guys PCF files to import into Caesar for their stress model. Sometimes it doesn’t work so we give them ISOs from plant 3D.
I’m trying to increase productivity since modelling existing with structure/pipe measurements and tie ins is very time consuming.
As per the clash detection part, we have one license of LFM clash detection but I assume it will be more expensive then Navisworks manage, not sure about this.
We currently ask for the surveyor to provide us recap files after they give us the LFD or we just make it our selves via gateway to e57 to recap if the ZFS files do not import to recap.
We use the embedded NWD Recap in the NWD with our plant 3D model for model reviews and as a final deliverable so the contractor can see during construction.
It seems like you can do Navisworks clash defection with recap ? Again, haven’t used the software. I’m not sure what is better in terms of cost to benefit.
Thanks all !
Mokeefe
Full Name: Mark OKeefe
Company Details: Clearedge3D
Company Position Title: Clearedge3D
Skype Name: markokeefe4
Has thanked: 27 times
Re: LFM Modeller + clash detection LFM VS Navisworks
Post by Mokeefe » Tue Sep 03, 2019 9:25 pm
If you do get stuck with having to create an As-built model. Edgewise might help (quick overview- https://www.youtube.com/watch?v=ma4IyaWR4ko). It handles piping really quickly, and is pretty good for structure depending on the project.
The other piece is running clash detection in Navisworks. I have a way to run clash detection of a point cloud against geometry in Navisworks :idea: . Is that helpful? DM me if you want to talk more.
Good luck!
mhuynh1031
Post by mhuynh1031 » Wed Sep 18, 2019 1:53 am
Hi Mark,
Thank you for your reply. Unfortunately, my office is not looking for software beyond Aveva.
We currently do not have an issue modelling existing but it can be very time consuming. I know edgewise can recognize existing, but we try not to model existing too much. To clarify, i'm not looking for so much a how to, but more of x1 vs x2. I am looking for user experiences with LFM modeller, LFM clash detection and Navisworks Manage Clash detection.
Our workflow:
  • Turn LFD to RCP for visual clash and NWD embedded laser scan for model reviews via recap pro
  • Using LFM Server and AutoCAD Plant 3D to design and model as per project scope
  • Model some existing runs to stress analysis for applicable piping via PCF to Caesar II
  • Use Navisworks NWD with merged RCP for visual clash check
  • Produce Isometrics/Orthos deliverables
  • P&ID are dumb and are manually cadded (not part of AutoCAD Plant 3D P&ID)
Questions
  • Can you link LFM modeller in AutoCAD Plant 3D like LFM server?
  • Has any1 tried to LFM modeller in bubble view/in volumes?
  • If so, how much time it save you VS measuring and using tie-ins in LFM server?
  • How did you find LFM clash detection VS Navisworks Manage clash detection?
  • Is it even worth doing clash detection against the existing for brownfield work when the area is very congested?
Graham
Full Name: GrahamM
Company Details: AVEVA
Post by Graham » Mon Sep 23, 2019 9:56 am
I recommned speaking with LFM Support as there has been a lot of new work on clash reporting and management in the latest LFM builds.
mhuynh1031
Post by mhuynh1031 » Mon Dec 09, 2019 4:37 pm
Since there as been no replies to answer my question, I will answer my own
not sure on this one, apparently, LFM modeller hasn't updated or invested in that software
Clash detection on LFM seems to be way better than navisworks manage. LFM allows you to clash with user-defined volumes and not static point cloud. It is also a lot quicker
  • is it even worth doing clash detection against the existing for brownfield work when the area is very congested?
Clash detection is good, but it does require filtering for brown fieldwork. If you create a demo volume, you are introducing human error. I think it is best to run hard clash detection and approve what is not applicable.
Return to “AVEVA Suite”
