AutoCAD 3D Model into Pointools
Discuss all Bentley Pointools related issues here.
boxel0
I have made 80-90 posts
Full Name: Lewis Boxer
Company Details: Advanced 3D Laser Solutions Ltd
Post by boxel0 » Mon Jul 04, 2016 10:52 am
We have created a 3D model in AutoCAD 3D using 3D point cloud data
Now im trying to import point cloud data and the 3D model into Pointools and have them both aligned.
I can get the point cloud data into Pointools, by exporting it as a .pod file from faro scene.
But when it comes to exporting the model from autocad, i tried exporting it as a .dwg but pointools wont import it at all. So i have tried using the .obj format, which goes into pointools, but its scaled up bigger that the pointcloud.
Look forward to hearing your thoughts
Lewis Boxer
Technical Director
e: lewis@lasersurveying.com
w: www.lasersurveying.com
fj-Bentley
Full Name: Felix James
Company Details: Bentley systems
Company Position Title: Support Engineer Senior
Country: England
Re: AutoCAD 3D Model into Pointools
Post by fj-Bentley » Wed Jul 06, 2016 2:16 pm
The only options you have for bringing a 3D model in to Pointools are OBJ or 3DS format. It should be coming in at the correct scale. Can you confirm which version of Pointools you are using? If it is coming in large you also have the option of changing the scale under the object properties however this shouldn't be necessary.
TimBeach
Full Name: Timothy Beach
Company Details: Malcolm Hollis
Company Position Title: Associate - Measured Surveys
Post by TimBeach » Wed Jul 06, 2016 11:36 pm
I always found that .3ds worked best for me when getting models from CAD into Pointools.
It did involve going FBX through 3ds max but seemed to work.
Tim
Return to “Bentley Pointools”
