amberg users
- Full Name: olivier boissard
- Company Details: GGC
- Company Position Title: laserscanning surveyor
- Country: France
amberg users
Hello
is there any amberg TMS users on this forum ?
In noticed only a few post ...
olivier
olivier
- Phil Marsh
- Administrator
- Full Name: Phil Marsh
- Skype Name: phil.h.marsh
- Has thanked: 117 times
- Been thanked: 36 times
Re: amberg users
Hi Olivier,cerene_olivier wrote:is there any amberg TMS users on this forum ?
I'm an Amberg TMS user, is there anything you need to ask?
Phil
- Country: France
Re: amberg users
Hi Phil
I imported a HDS6000 pointcloud into TMS Tunnel.
I extrated profil with TMS profit
There is a lot of work to do to clean it.
I wonder if it was possible to clean several profil at a time ( because the same noise data appears in consecutive profiles) ?
Is it possible to reject isolated point after profil generation ?
Olivier
Olivier
- Phil Marsh
- Administrator
Re: amberg users
Hi Oliver,
It is possible to delete (MASK) points in the scan data (Map view). After the masking these points are not visible in the profile data so do not show after the export.
I hope this helps?
Phil
I hope this helps?
Phil
- Country: France
Re: amberg users
Hi Phil
I don't find where to mask these points.
In which module ? ProFit ? scanrex ? scancloud ?
Is it possible to mask for ALL profils ?
Olivier
Olivier
- Country: France
Re: amberg users
Hi
I realized you probably tought about scanCloud.
As a matter of fact it is possible in this module to mask scan data but AFTER processing
The problem is that I have huge quantity of data in this scan and the process is very very long
So I try to generate profils without surface data processing.
That 's why I try to clean data before data processing.
Do you know a method to mask these points BEFORE data processing ?
Olivier
Olivier
- Full Name: Marco Meroni
- Company Position Title: Tunneling and Rail Technical Support
- Country: Italy
Re: amberg users
in TMS you can't mask point before data processing. But to have a quick results from processing you can try to use the "Quick Processing" option in the "Processing Parameters".
With this option you can reduce the cloud projection to obtain quick results (for example directly in the tunnel).
I hope this can help you.
Markko
Markko
- Country: France
- Country: Italy
Re: amberg users
This option is available in TMS version from:
1.9.0.0 [approximately October 2009]
You can find the "Quick Processing" option opening "Scans" in the Workspace of TMSOffice, then go the menù:
"scans" >>> "processing parameters"
In this window you can see it (in the bottom part of the window).
Ciao
Markko
Ciao
Markko
