We are a small surveying setup with very little experience in Laser Scanning & have a potential scanning job coming up.
We had some experiences with Leica 3DR software and would like to use that as our main software to generate the required output & reporting. The scanner itself would be rented and we have either Trimble or Faro scanner offered at a reasonable rental rate.
The question is, would there be any problem or complication in getting the raw data from either Trimble or Faro to go straight into Cyclone 3DR? We want to avoid spending time in learning either Trimble or Faro scanning software suite if we can help it. TIA
Mix & Match Hardware & Software
- Full Name: Martin Graner
- Has thanked: 160 times
- Been thanked: 175 times
Re: Mix & Match Hardware & Software
This is hard to answer. So to my knowledge this should be the current possibilities:ard wrote: ↑Fri Jan 27, 2023 2:16 am We are a small surveying setup with very little experience in Laser Scanning & have a potential scanning job coming up.
FARO raw scan files can get imported into 3DR, unless it is the new Focus Premium scanner, but it is possible that colour can't get read.
Trimble raw scans can't get imported.
If you have the software to the scanner and you can export an E57, then it should be possible to use either scanner.
- Justin Richards
- Full Name: JUSTIN RICHARDS
- Has thanked: 38 times
- Been thanked: 51 times
With the Faro Premium, you might have to bring scans in to Scene LT to export them as E57
- gsisman
- Full Name: Steve Long
- Skype Name: gsisman1
- Has thanked: 767 times
- Been thanked: 149 times
Someone can correct me if I'm wrong but 3DR as far as I know ISN'T a registration software. The RAW scans would need to be registered together somehow outside of 3DR before ingesting into 3DR. We need to look at 3DR closer since all the old Cyclone Core processes are slowly being integrated and updated into Register 360 and 3DRVXGrid wrote: ↑Fri Jan 27, 2023 11:17 amThis is hard to answer. So to my knowledge this should be the current possibilities:ard wrote: ↑Fri Jan 27, 2023 2:16 am We are a small surveying setup with very little experience in Laser Scanning & have a potential scanning job coming up.
- LPaulCook
- Full Name: L Paul Cook
- Has thanked: 47 times
- Been thanked: 44 times
I use FARO X330 and S350 scanners and processes/registration in FARO's SCENE software. The rental scanner should come with the software for the instrument for a short time.
I own 3DRESHAPER program and I export from SCENE to e57 files which I import to 3DR. Color comes thru fine if you scan in color. Color on the FARO scanner can take longer than the scan! I added a 360° camea on top that takes 2 seconds to color the scans. If you need color ask about including the 360° top mounted camera.
3DR does not process or register raw scans.
How do you plan to register the scans and what are you scanning?
L. Paul Cook, PLS
www.LPC3D.com
www.LPC3D.com
