Command line e57 to ptx conversion?
- Full Name: Jed Frechette
- Company Details: Lidar Guys
- Has thanked: 62 times
- Been thanked: 219 times
Does anybody know of any command line tools that can convert structured e57 files to ptx format?
- Felix_the_Cat
- Full Name: Felix
- Been thanked: 26 times
Re: Command line e57 to ptx conversion?
I believe cloudcompare has a fairly robust command line interface and can perform the task
https://www.cloudcompare.org/doc/wiki/ ... _line_mode
Steep learning curve though
Good luck
Good luck
Unfortunately, CloudCompare doesn't have a ptx writer. I believe it also treats all e57 files as unstructured. So both of those features would need to be added to make use of it's command line interface for this task.
- Felix_the_Cat
- Full Name: Felix
My bad, I forgot it doesn’t do ptx and I didn’t read the structured part so my reply is wholly useless, sorry for wasting your time.
You are using cyclone or zf? I understand the need for the structure but file sizes that never get smaller kind of suck.
One of a multitude of reasons why I’m trying to get away from Leica/cyclone...always moar MOAR $$$$$$$$$$$$$$
No worries, all responses are helpful, even if just confirms I I haven't missed anything.
We're not using Cyclone or ZF directly, but end up working with data from various sources so some data will have originated in them.
- Full Name: James Worrell
- Has thanked: 14 times
- Been thanked: 87 times
Check out FME desktop - although you may need to split the E57 first to handle it as structured. Last time I played it converted the E57 to LAS as an intermediate format or something off the top of my head - I was going to Recap tiles for that one.
Thanks for the suggestion. It looks like FME doesn't support .ptx either though
- steves01x
- Full Name: Steve Smith
- Company Details: Scanning
- Country: Scotland
- Has thanked: 31 times
- Been thanked: 57 times
A long manual task = import e57 to Cyclone then export as ptx?
Manual tasks is exactly what I'm trying to avoid. I want to be able to schedule jobs to do the conversion overnight, while I'm sleeping.
- steves01x
- Country: Scotland
Depending on the size of the data / hard drive space you could batch import the e57 to Cyclone, export it one massive file as ptx then use the ptx splitter ?
Forum post with splitter >> viewtopic.php?t=6040
