Which scanner allows traversing
- landmeterbeuckx
- Full Name: Lieven Beuckx
- Country: Belgium
- Has thanked: 183 times
- Been thanked: 548 times
Re: Which scanner allows traversing
Good discussion. My goal is to traverse through a site (building, road or forest) with a start- and endpoint which will be definately measured, some traverse points in between when possible to avoid placing multiple spheres and moving them around.
I'm not interested in corrected station points on site but will calculate these through my sureying software. So i'm in need of HA, VA en oblique distance measured on a prism.
The placing of spheres is cumbersome especially in busy and dense situations with people knocking or moving the spheres.
A system like the leica M series and new trimble are exluded as the speed of scanning isn't like a normal scanner and i already have all the traditional surveying gear and software.
Free stationing would be a nice feature but i'd prefer traversing.
- Full Name: James Worrell
- Has thanked: 14 times
- Been thanked: 87 times
"Traversing" with the C/P series Leica's still requires you to be able to see multiple targets per station .. although I suspect the distances are a bit better than spheres? We get about 110 - 120m with the C10's for example to a 6" target. Minimum two per station .. prefer 3+ for redundancy .. and I mentioned before about a traverse "mesh" .. in some stations you might pick up 6 targets say linking multiple loops together. Cyclone does a great job with this ..
I guess traversing can be defined as in-instrument or in-office. The result is exactly the same - scans go together - same as if you do a traverse adjustment when you get back in .. you have placed targets, read to them, booked the results and calc'ed it.
With our targets we have added brass spacers etc to match instrument heights so we all the tape measures work, forced centering is an option etc. Not an issue if I recall with the new P40 - the targets now match? With the tribrachs we can obviously replace with a prism if working in conjunction with a total station, we also have the smart handle so we can put a prism on the scanner and read to it as well if we are really motivated.
- Full Name: Fabien
- Company Details: Amec Foster Wheeler
- Company Position Title: Geomatics Project Manager
I have used the Leica P20 for traverses and sideshots, just like a total station. There is not much difference compared to conventional surverying. You get a closure, same concept of a closed figure traverse or open end traverse. We get as good as of a closure and in most cases better compared to a total station. You need less targets (backsight and foresight target). You get a registered data at the end, get a sketch, make adjustments with the Leica Pseries. We use the traverse method very often with most of our non DOT projects, and it works great.
- Full Name: Chris Harris
- Company Details: Trimble
- Company Position Title: Sales Account Manager - Geospatial EMEA
- Been thanked: 5 times
You could try a Trimble SX10. Fully robotic total station and 360° scans in minutes. Because it is a total station you get all the traditional setup methods, resections, traversing, network adjustments etc... If you then require further adjustment in the office then the scan data is adjusted for you.jcoco3 wrote:James, I think you just confirmed much of what I said about "traversing" with a laser scanner. Thanks Seems like it is a far cry from traversing with a total station.
Its a great piece of kit.
- jcoco3
- Full Name: Jonathan Coco
- Company Details: Consultant
- Has thanked: 70 times
- Been thanked: 157 times
I mentioned the SX10 earlier in the thread, but he doesn't like the low capture rate.
- landmeterbeuckx
- Country: Belgium
My objective is to traverse with a scanner and measure the start and endpoint (or points in between) with a total station or gps and digital level.
I have already got the other equipment. If i need to traverse for construction layout or something which requires mm-precision i would use a total station.
As mentioned in https://laserscanningforum.com/forum/vi ... 47&t=11009 thread i find combi instruments like a combi-oven, seperate machines run better.
Also the speed of scanning is too slow. These instruments Trimble SX10 or Leica M-series might have potential clients for them but i am not one of them. No offence for people who use them.
Processing doesn't need to be on site. I rather have full control behind my pc.
No users of the GLS-2000 as all of my opther gear is Sokkia-Topcon.
- Full Name: Fabien
Then your best option is a Leica P series scanner (In my opinion and by experience). I have done exactly what you are wanting to do. Traverse, set side points that I can go back to, even a conventional surveying crew could use.landmeterbeuckx wrote:My objective is to traverse with a scanner and measure the start and endpoint (or points in between) with a total station or gps and digital level.
- Full Name: Scott Page
- Has thanked: 206 times
- Been thanked: 78 times
From SPAR, today:
Low-Cost Lidar Changes the Game for Service Providers
http://www.spar3d.com/blogs/confessions ... providers/
Excerpt:
"For years I have disparaged Leica’s onboard Traverse and Resection tools, as I had Cyclone’s Virtual Surveyor tool. I viewed them as marketing gimmicks to hook land surveyors into scanning. Gimmicks that, in my opinion, kept these surveyors from learning the better methods of data capture and field methodologies that I had learned from marine and offshore scanning techs–guys who looked at land surveyors as crude measurement guys with dirt on their boots!"
Excerpt:
- I have made 50-60 posts
- Full Name: Jason Hayes
- Company Position Title: Product Manager 3D Scanning Software
Not sure if you are using Trimble RealWorks with the TX5 but in version 10 there is a station setup routine to mimic the workflow you would use in the field with a total station. This is useful for scanners that don't have this capability built in. You can select a control point from a list or manually enter the coordinates for the instrument and then select a back sight from the scan. You would need to keep field notes of the scanner heights and the target heights so that you could enter them back in the office. This would at least enable you to avoid putting out so many spheres and also ties you to control points at the same time. I don't remember if there is a height measurement mark on the TX5 or FARO scanners so you might need to find that.
