BLK 360 - Image black zone
Introduce yourself.
ZenithSAS
6
Full Name: Philippe Motte
Company Details: Zenith SAS
Post by ZenithSAS »
Hello Everyone,
Since I installaled the last firware of the BLK360 (1.1.6), I had a new problem when taking photo.
It seems that the panoramic photo does not cover all the scanned data (the lower part), so this part is textured in black.
If I compare the point cloud in intensity color, and the one in color photo, I can see that problem (I voluntarily changed the background color into grey).
The problem is that on an assembly of several stations, it makes appear circular areas not very sexy.
Has anyone ever observed this problem?
Philippe MOTTE - French User
ZENITH SAS
GavFoster
14
Full Name: Gavin Foster
Company Details: Offset Services Ltd
Company Position Title: Photogrammetry - Laser Scan
Has thanked: 4 times
Re: BLK 360 - Image black zone
Post by GavFoster »
I am seeing just the same problem ('Feature') here.
Currently working through different methods to try to fix it.
Gav
pburrows145
16
Full Name: Paul Burrows
Has thanked: 109 times
Been thanked: 123 times
Post by pburrows145 »
ZenithSAS wrote: Fri Mar 09, 2018 8:59 am Hello Everyone,
In which software are you processing the data? Are you collecting with/without an iPad?
Yuelin
I have made 90-100 posts
13
Full Name: Yuelin
Been thanked: 11 times
Post by Yuelin »
I guess you are using Cyclone 9.2.0. Cyclone trims the bottom part of image, and it causes points at this area don't get color. This behavior should have been changed in Cyclone 9.2.1.
ZenithSAS
6
Post by ZenithSAS »
I have thé same results in HDR and LDR, by importing the data into Cyclone 9.2.1 with or without using the ipad.
If I import a project Register 360, I also observe this, with in addition, a shift of the texture (another topic)
ZENITH SAS
greg_at_ppm
7
Full Name: Greg Davies
Company Details: Precision Property Measurements
Company Position Title: Precision Property Measurements
Post by greg_at_ppm »
I get the same results regardless of registration workflow (Recap Mobile Pro, Cyclone Register 360). In my case, however, the points just look grayscale - not black. This occurs using LDR and HDR. I assumed Leica just goofed and poorly calibrated the cameras to the lidar output preventing a full colorization of each scan. Perhaps it is a firmware issue, but I wouldn't know as we've done all of our work with BLKs on whatever version came before 1.1.6 and after the original firmware release (1.0.0?).
pburrows145
16
This issue will be fixed in an upcoming release.
ZenithSAS
6
Post by ZenithSAS »
Perfect... thank you for your help Paul !
ZENITH SAS
Return to “Introductions”
