Hi All,
My name is Fred, I'm 44 years old and from South-Africa.
I am about to enter the world in 3D scanning.
My backround:
Design draughtsman (Designer), Civil, structural, mechanical and piping. 22 years working for EPCM companies (mining, process plants, petrochemical and Pharmaceutical)
In the last 2 to 3 years I have mostly work for myself servicing smaller clients that requires help with smaller projects and don't want to make use of large EPCM's as the costs are too high. This is where I would like to focus the medium size companies that do not have engineering departments and do not want to permanently employ people to do this. I mostly work on existing expansion projects where engineering drawings does not exist (so this requires a lot of site measuring up hense the requirement for 3D scanning).
I need advise regarding:
Equipment, software and hardware.
I am looking at the Faro focus 3D s120 laser scanner and the freestyle 3D handheld.
I have read a lot on processing requirements and need help selecting a suitable laptop and desktop and the scene software (need recommendations regarding software).
Can the scans be done by me and the point clouds processed by an outsourced company that specializes in it (this will save me buying expensive PC and software?
Kind Regards
Fred
Greetings from South-Africa
- Full Name: Fred
- Company Details: Private
- Company Position Title: Pvt
- Country: South Africa
- Skype Name: fbez101
- Full Name: Scott Page
- Has thanked: 206 times
- Been thanked: 78 times
Re: Greetings from South-Africa
Welcome to the forum![email protected] wrote:Can the scans be done by me and the point clouds processed by an outsourced company that specializes in it (this will save me buying expensive PC and software?
To answer your last question -it is possible to have others process your scan data, but you will not fully understand the workflow unless you do the work yourself for a while. I've learned more from the registration process than from doing the actual scanning. You don't need a workstation to do the registration in FARO Scene -just have at least 16gb of RAM and a decent i7 processor. There are many threads on hardware requirements found on the forum. Good luck!
- NOVAMECH
- Full Name: Nick Bush
- Company Details: NOVAMECH
- Country: New Zealand
- Skype Name: novamech5
- Has thanked: 9 times
- Been thanked: 9 times
Welcome to 14 hour days, returning to the office to work until midnight. Nothing about running a 3D scanning business is easy, cheap or quick. - I hope you are dedicated, or at least motivated.
- steves01x
- Full Name: Steve Smith
- Company Details: Scanning
- Country: Scotland
- Has thanked: 31 times
- Been thanked: 57 times
As has been said, process your own scans - you will learn so much more about the scanner and best approaches in the field. Check your work in the field... as you never know when you might miss something or get a dodgy scan etc
My laptop was about £1600 over a year ago from (https://www.scan.co.uk/3xs ) and it can handle pretty much everything i have thrown at it in Cyclone and Scene. One area i wish i had upgraded was a larger SSD drive and the 2nd drive should of SSD also.
