Pros & Cons of using TLS for mobile mapping
MDL Dynascan, ABA Mobile Mapper, StreetMapper, IP-S2 Topcon, RIEGL VMX450, Leica Pegasus One, etc
eric_low
Full Name: Eric Low
Company Details: Singapore Land Authority
Company Position Title: Snr. Executive
Country: SG
Post by eric_low » Wed Feb 05, 2014 4:31 pm
Hi Everyone
I will like to seek opinion on mobile laser system.
In the market, we have the MLS system from Optech, Reigl etc vs the TLS/profilers converts MLS system. Will the TLS/Profiler system performs well in speed range of 60km/h and above to collecting data for engineering and mapping usage. What will be the typical speed to drive at if I am interested in mapping road as well as lamp post & signages.
Thank you
Eric
Alexander Freydin
Full Name: Alexander Freydin
Company Details: GSI
Company Position Title: engineer
Country: Russia
Skype Name: alexander_freydin
Re: Pros & Cons of using TLS for mobile mapping
Post by Alexander Freydin » Thu Feb 06, 2014 8:17 am
I would look at this question from other side.
What accuracy and points density you need?
It absolutely clear - if you drive at 30km/h and at 60km/h the point cloud will not the same.
So if you relly interested in mobile scanning - try to order demo of different systems on a real road and compare the results at different speed. It will be the best answer.
eric_low
Full Name: Eric Low
Country: SG
Post by eric_low » Fri Feb 07, 2014 1:08 am
Alexander Freydin wrote:I would look at this question from other side.
Hi Alexander
Thanks. Apart from factors like accuracy, point density and limitation by vehicle speed, are you aware of any other tricky issue with TLS/profiler type of MLS system?
ksyen
Full Name: Kin Yen
Company Details: University of California Davis
Company Position Title: Development Engineer
Country: US
Post by ksyen » Tue Mar 24, 2015 8:36 pm
TLS generally has slower scan rate (mirror rotation speed) and a limited FOV (field of view <360). However, I think some new TLS (eg. P20) can spin higher when powered with vehicle power.
It is "cheaper" if you don't do MTLS all the time to use TLS for MTLS.
But a big part of the MTLS cost is software license, training, and personnel time.
Return to “Mobile Scanners”
