Laser Scanner for Surveying Roads at 100 km/h
ABA Mobile Mapper, IGI StreetMapper, Leica Pegasus One & Two, MDL Dynascan, RIEGL VMX450, STORMBEE BEEMOBILE, Topcon IP-S2, Trimble MX50, etc.
Phil Marsh
16
Full Name: Phil Marsh
Skype Name: phil.h.marsh
Has thanked: 117 times
Been thanked: 36 times
Post by Phil Marsh »
The Fraunhofer Institute for Physical Measurement Techniques IPM has developed a laser scanner for measuring road surfaces with high precision. A single high-resolution laser scanner scans the topography of the road surface across a span of four metres. Even at speeds of up to 100 km/h, measurements are accurate to between 0.15 and 0.3 millimetres. In cooperation with a road surveying specialist, Fraunhofer IPM has already scanned a total of 15,000 kilometres of highway and other major roads across Germany.
Thumbnail Screenshots by Thumbshots
LASER SCANNING FORUM
Phill
16
Full Name: Phillip Nixon
Company Details: SKM
Has thanked: 7 times
Been thanked: 45 times
Re: Laser Scanner for Surveying Roads at 100 km/h
Post by Phill »
I could be wrong but this is a profiler, correct? I guess it does measure in three dimensions, just not the three we would normally expect (offset, height, chainage as opposed to x,y,z)
bas
16
Full Name: Bas Kuckelkorn
Company Details: McMullen Nolan Group
Company Position Title: Engineer - HDS Manager
Post by bas »
I think you're right Phill, this is used for rutting, cracking, potholing, etcetera.
Not an MLS system in the sense you and we use it.
Honorary Member
Honorary Member
16
Has thanked: 45 times
Been thanked: 40 times
Post by Matt Young »
I have a similar system built into my car for finding pot holes :cry:
Return to “Mobile Scanners”
