Leica RTC360 vs Faro Focus S150
Please post all your polls you want others opinion on.
RTC360 vs S150
RTC360
122
46%
Focus S150
145
54%
Total votes: 267
pburrows145
16
Full Name: Paul Burrows
Has thanked: 109 times
Been thanked: 123 times
Re: Leica RTC360 vs Faro Focus S150
Post by pburrows145 »
Dmb06124 wrote: Wed Aug 07, 2019 4:27 pm One of my biggest concerns with the RTC360 is the file size. I'm hearing that time saved in the field with the quick scanning is lost during the handling of the scans back at the office. Has the new firmware done enough to fix this?
MajorDomo
5
Full Name: Major Domo
Company Details: VeritasVfx
Company Position Title: ceo
Country: Portugal
Has thanked: 17 times
Been thanked: 53 times
Post by MajorDomo »
That's a great table, it's more compressed for the looks of it.
Has the import speed remained the same, improved, or suffered a slow down?
pburrows145
16
MajorDomo wrote: Wed Aug 07, 2019 4:48 pm That's a great table, it's more compressed for the looks of it.
Machine dependent, I am seeing much improved import times for coloured and non-coloured scans with new FW and HW.
Running Xeon, 64gm Ram, Nvidia P5000 and SSD's.
sim.herrod
8
Full Name: Simeon Herrod
Has thanked: 73 times
Been thanked: 110 times
Post by sim.herrod »
We trialled both and went with the S150, but still mainly use full fat Cyclone to process.
Onsite reg works well if you remember overlaps, and moving object filter works well once you've got the setting dialled in.
Don't know if the RTC colour has changed with new FW, but Faro colour looks more 'real' based on what we saw.
Jamesrye
15
Full Name: James Rye
Has thanked: 28 times
Been thanked: 69 times
Post by Jamesrye »
sim.herrod wrote: Wed Aug 07, 2019 10:04 pm Don't know if the RTC colour has changed
We used an RTC360 on a project when it was first released and the colour was very disappointing. This has definitely been improved since then, and we are very impressed with the imagery that can now be acquired. I think the latest firmware also lets you export panos.
pburrows145
16
Jamesrye wrote: Thu Aug 08, 2019 8:39 am
Here's a 3 example pano's from the new FW: https://www.dropbox.com/sh/7wx9mv7eisf6 ... 0kuWa?dl=0
jedfrechette
14
Full Name: Jed Frechette
Company Details: Lidar Guys
Has thanked: 62 times
Been thanked: 219 times
Post by jedfrechette »
Wasn't one of the recent RTC360 firmware updates supposed to add .exr panorama export? Could you share one of those?
pburrows145
16
That is nothing to do with the FW update per se, but an EXR is indeed exported when using a valid Cyclone Publisher Pro License to export your Pano image from Cyclone or Cyclone REGISTER 360. :geek:
I've added one here for you: https://www.dropbox.com/s/1nacns3pv6avg ... 1.exr?dl=0
Slewis33
10
Full Name: Shaun Lewis
Post by Slewis33 »
FARO On-Site registration works only on small projects and not with a tablet. With decent settings you have to stay under 20 setups, it is possible to do more with a laptop with lower settings and processing in BW then reprocess in color, but certainly not with a tablet.
S150 decent settings gets you 4:30-5:30 scan times with color. We are seeing much more interest in color point clouds now that scanning is main stream. I believe decent settings with RTC gets you 2:00-3:00 minute scan times, but I have personally not used it.
As far as range is concerned they really are similar, the FARO S150 shoots 150 meters but good accurate data is not 150 meters, I typically only rely on data at about 200' which in most cases is plenty.
MomentEng
5
Full Name: Jeremy Guillory
Company Details: Moment Engineering
Post by MomentEng »
Im running my S70 at 1/4 and 4x quality with color and im scanning around 10 min. each and i get great data. when i cut it back, i find that the point cloud isnt dense enough to pick up my control points (checker targets) unless they are really close. I think to get a 4 min scan with color, the resolution is super low. also, i run a hard stop at 120 feet. if i remember correctly, that will give a 0.125 in angular accuracy...I don't think the S150 will do much better.
when i do projects that are 500+ scans, I'm selective about which areas get the 1/4 and ill cut it back to 1/5 for the general scans and those run about 6-7 min with 4x quality.
But all this depends on what works for the project / client.
Return to “Opinion Polls”
