BLK360 wow new Leica/Autodesk scanner
CAD Workstations, Network Attached Storage [NAS], Servers, Monitors, SSD`s, Imaging Systems, Field Kit: Targets & Tripods etc.
tbwester
11
Full Name: Thad Wester
Re: BLK360 wow new Leica/Autodesk scanner
Post by tbwester »
3DForensics wrote: I can't read the future, but I think we may be onto another big disruption, much like the one that happened with the release of the Focus. Well done Leica.
Eugene
I agree. will be similar to the focus 120, just another step up.
tomii7
14
Full Name: Tomasz Gerlich
Skype Name: tomek.gerlich
Has thanked: 5 times
Been thanked: 7 times
Post by tomii7 »
If I can add my 2 cents in the end, BLK360 laser scanner seems to be a very good for internal scanning.
Outside we need still massive good scanner something like C10/P40.:)
Anyway this scanner more similar now to 'small scanner from Prometheus movie';).
cheers
TG
Best Regards,
Tomasz Gerlich
+44 7756613300
tbwester
11
Post by tbwester »
definitely. it is a scanner for buildings.
Rikore
8
Full Name: Bruce Yager
Post by Rikore »
I agree that the BLK360 will be a great addition to scan buildings with. Small, lightweight will make it easy to set in tight spaces. Having one or two in your arsenal, perhaps along with a good hand scanner will help to cover most situations you may run into.
pburrows145
16
Full Name: Paul Burrows
Has thanked: 109 times
Been thanked: 123 times
Post by pburrows145 »
One of my colleagues mentioned a "Swarm" field work-flow with multiple scanning devices. One P-series and a load of BLK360's all playing nicely...Still lots to consider regarding the workflows.
Will be interesting to understanding if one IPad Pro with the Recap 360 Pro App could control multiple devices... either individually or (perhaps eventually) concurrently.
For all HDS Users attending our event on Thursday in the UK, this will be your first chance to see the unit (unless you were lucky enough to attend AU).
16
Has thanked: 443 times
Been thanked: 246 times
Post by Jason Warren »
jamesworrell wrote: Fri Nov 18, 2016 10:18 pm So just to recap (pun?) ..
- 1kg
- bloody tiny
- onboard storage?
- a 40" IMU
- not _that_ expensive (that you can't crash the odd one here and there)
- IP rated
- robust body design
So I'll just leave this MOCK UP .. I repeat this is just me crystal ball gazing .. here. Mind. Blown.
Like it ;o)
Co_Founder
LaserScanningForum
s.cadman
7
Full Name: Stephen Cadman
Company Details: leeds beckett university
Company Position Title: cad manager
Country: uk
Post by s.cadman »
Does anyone know if it's possible to get data directly from the scanner to a laptop running recap with using an iPad?
My laptop sees the wifi network generated by the scanner and does connect.
thanks
Ryan
15
Full Name: Ryan Frenz
Company Details: Autodesk
Post by Ryan »
Sorry but direct transfer from BLK to ReCap Pro (non-Mobile) is not supported at this time.
-Ryan
phamduysc
9
Full Name: Duy Pham
Company Details: Land Surveys
Company Position Title: Project surveyor
Skype Name: phamduysc
Post by phamduysc »
Hi, I just tested BLK 360 with some Leica guys. We did scan with high resolution then import to Cyclone ('cause they only have Cyclone to import BLK data) But for some reason, we cannot export BLK's data to PTX or E57 or any other.
Does anyone here know how to export BLK's data from Cyclone?
Duy Pham | Surveyor
pburrows145
16
phamduysc wrote: Tue Aug 15, 2017 3:50 am Hi, I just tested BLK 360 with some Leica guys. We did scan with high resolution then import to Cyclone ('cause they only have Cyclone to import BLK data) But for some reason, we cannot export BLK's data to PTX or E57 or any other.
You can only IMPORT BLK360 data into Cyclone, not export it. You can export it in most pointcloud formats available from within Cyclone export menu.
Return to “Other Hardware: Field & Back Office”
