Has anyone tried any of these camera jibs? I was about to start to have our shop fabricate a counterweighted arm with an adjustable base but if I can just modify a higher end jib...I may go that route
https://www.cameragrip.com/libec-camera ... b-50-kit/
Backstory- Need to get out of windows and roofs fairly frequently so i would like a flexible solution for our Faro M70
Scanning out windows/roofs
- I have made 30-40 posts
- Full Name: William Fletcher
- Company Details: AEC Industry
- Company Position Title: Design Technology Manager
Re: Scanning out windows/roofs
with over 200 views and no comments, this is not looking promising
Maybe I will turn this into my fab thread here as I have our shop build an adjustable dolly on casters with an extendable arm
Unless anyone can convince me to go the jib/boom route
- topogeo
- Full Name: piercarlo roasio
- Company Details: studio roasio
- Company Position Title: titolare
- Country: italy
- Has thanked: 24 times
- Been thanked: 25 times
very interesting but .. expensive solution.
For my BLK360 it would take a "light" version that should only support 1 kg.
You could eliminate the wheels of the lower part ... A "normal" fixed tripod would be enough or better yet ... you could have only the extendable arm (with the counterweight) to be fixed on a normal topographic tripod (5/8 " )
Furthermore, once the arm has been extended, it must be possible to block every movement (scanning requires that the support is fixed).
Piercarlo
Piercarlo
- Country: Italy
- Has thanked: 15 times
- Been thanked: 53 times
In the past possible solutions to scan out of windows and roofs have been discussed and diy solutions posted. I cannot find them at the moment but there is stuff in the forum..
- Wags
- I have made 60-70 posts
- Full Name: Wayne Wagner
- Company Details: Unlimited Image Inc
- Company Position Title: New Product Development
- Skype Name: wags
- Been thanked: 2 times
One solution might be this with a wifi connection to the scanner
- 15
- Full Name: James Rye
- Has thanked: 28 times
- Been thanked: 69 times
Using a jib arm worked for me:
viewtopic.php?t=12531
More useful solutions:
viewtopic.php?f=55&t=7088
