I am newbie into scanning import/ conversion and I need some help, please.
we have received a scan in ZFC format and would like to import it into Cyclone v7. Is there any way to convert the ZFC files to IMP in order to do this? In the received scan we there are ZFC files, PNG files, one LFD file, one LFR file. The issue is that I got no documentation of what was used to generate the scan or which software is needed to open them.
Thank you!
ZFC to IMP - import into Cyclone v7
- Full Name: Radu Popa
- Company Details: Tecon Engineering SRL
- Company Position Title: IT Administrator
- Country: Romania
- Full Name: David Langley
- Company Position Title: Applications Engineer
Re: ZFC to IMP - import into Cyclone v7
I have attached a pdf with the steps to import a .zfc into Cyclone. Please feel free to contact me with any further questions.
- Peyman Bashiri
- Full Name: Peyman Bashiri
- Company Details: Aero Geometrics Canadian Z+F reseller
- Company Position Title: Laser scanning and BIM Specialist
- Skype Name: pbashiri2003
- Has thanked: 56 times
- Been thanked: 40 times
Why do you need to do the step 4? converting to Enhanced working format?
Peyman
Peyman
- Country: Romania
Hello and thank you for the answer! After opening the ZFC in Cyclone I can see the cloudpoints, but not the PNG images ( only the scanned frame is visible). Is there anything I should add/import in order to see the pictures as well?
There are around 500 ZFC files. Can they be grouped into 100 sets and generate an *.IMP for each set? If yes, then how, plsease?
And in order to only view the scans what software can be used?
Regards!
Regards!
- Full Name: Bill Wallace
- Company Position Title: HDS Sr. Software Product Manager
As far as I know, they only format that can be used to transfer image data is e57. Can you save the project you have to e57 from whatever software it is living in?
- Peyman Bashiri
If your .ZFS point cloud files already colorized in ZF control, then when you import it to Cyclone you should see the RGB value in point cloud.
But I would love to find a way to see the panorama images took by ZF scanner in Cyclone not just the colorized point cloud.
By the way instead of importing the All .ZFS file one by one you can import the .zfprj to import all scans at once just remember to check the "estimate normals"
- Full Name: Andrej
- Company Details: Meixner Vermessung and Freelancer
So why is Cyclone or other software (Realworks, Scene, ReCap) not importing the images? E57 is good but the photos are useless as we don't have a way to utilize them in other software.Bill-Wallace wrote:As far as I know, they only format that can be used to transfer image data is e57. Can you save the project you have to e57 from whatever software it is living in?
Does anyone know a software which will take the photos from a E57?
- Full Name: Martin Kerfoot
- Company Details: LFM Software Ltd.
- Company Position Title: Channel Manager Asia
- Country: Malaysia
Hi Radu,
The .ZFC and .LFD files you have are to be used in LFM software. You can use them directly in LFM and don't need to convert anything.
If you contact [email protected] or [email protected] then someone will be able to speak to you regarding using these files.
From reading your post it seems like you're using the point cloud in a CAD design system. LFM supports Autodesk, Bentley, AVEVA, Intergraph and Siemens so my recommendation would be for you to try and use the formats you have already in the most efficient way.
FYI the photo realistic panorama images (BubbleViews) are maintained in LFM software so if these are important to you I'd definitely recommend a trial of the software.
I've let the support team know to expect an email from you. I won't ask for you to publish your contact details here.
Kind regards,
Martin
Kind regards,
Martin
- Country: Romania
Hello and thank you for your answer! I have sent a mail to the indicated address and also posted a request for a trial license on the website. All I get back is:MartinK wrote:Hi Radu,
Kind regards,
Martin
"According to our records, your query has been resolved. If you have any further questions or concerns, please respond to this message."
But according to my records, my querry has not been resolved...
