Elevated Tripod
Discuss all Z+F related issues here.
Vincent DENIS
Full Name: Vincent Denis
Company Details: Geopole
Company Position Title: Surveyor Scan - graphic designer 3D
Re: Elevated Tripod
Post by Vincent DENIS » Mon May 15, 2017 1:50 pm
Thank you for your returns !
I'm not motivate to just use the faro on a base (if it's not completly horizontal ...) but #NOVAMECH on your picture, your deck with base look great!
Do you know where can i found a similar ?
NOVAMECH wrote:Solution, 1 box of beer, invite some mates over (not to many as you only have 1 box)
Burn - ALL wooden TRIPODS. Problem solved. Why anyone still uses these - I can not fathom???
I have a few other tripods, but this is the CORE - In reality you only really need the LAT 295 and the Trivet Plate.
The LAT295 - packs down to the smaller LAT195 units size - but is slightly heavier. Still a 1 hand lift.
Rkillenberger
Full Name: Robert Killenberger
Company Details: Precision Point Inc
Company Position Title: 3D Laser Scanning Solutions Specialist
Re: Elevated Tripod
Post by Rkillenberger » Mon May 15, 2017 3:16 pm
Hello! My name is Robert, I'm with Precision Point Inc. I'm looking for a reliable Elevated tripod, we have gone through a hand full in the past but the crank seems to get really hard and ends up breaking.
What are you guys using and or recommend? open to any suggestions. thanks!
cadmium
Full Name: Jason Bayer
Re: Elevated Tripod
Post by cadmium » Mon May 15, 2017 8:02 pm
Rkillenberger wrote:Hello! My name is Robert, I'm with Precision Point Inc. I'm looking for a reliable Elevated tripod, we have gone through a hand full in the past but the crank seems to get really hard and ends up breaking.
This is the first elevator tripod we got. its a cheapie, and eventually one of the plastic levers broke off.
http://www.engineersupply.com/Northwest ... AkwR8P8HAQ
this is the second one we got, and the one that this post is about. much bigger and stronger, but heavy
http://www.tigersupplies.com/Products/S ... Au108P8HAQ
Rkillenberger
Re: Elevated Tripod
Post by Rkillenberger » Mon May 15, 2017 9:02 pm
Thanks for the reply! We have the second one you suggested, I have been searching today and found this one http://www.stakemill.com/index.php?main ... ts_id=4298
I think it might be a good candidate. 13' and only 25LBS! I think we are going to try this one out. let me know your thoughts!
NOVAMECH
Full Name: Nick Bush
Company Details: NOVAMECH
Country: New Zealand
Skype Name: novamech5
Re: Elevated Tripod
Post by NOVAMECH » Wed May 17, 2017 4:51 am
Here are some images of the TriVet Plate. Also, a drawing and DXF profile for plasma cutting. I find this a great tool to take on to site. Even if I don't need to scan low. I can place the scanner into this while moving the TriPod. No need to open and close the case every time you move. You may ask what this the masking tape for? Well I set the orientation of the scanner at the ZERO point - at this corner. Thereby being able to scan a sector with ease and not having to scan a full 360.
Vincent DENIS
Re: Elevated Tripod
Post by Vincent DENIS » Wed May 17, 2017 7:19 am
NOVAMECH wrote:Here are some images of the TriVet Plate. Also, a drawing and DXF profile for plasma cutting. I find this a great tool to take on to site. Even if I don't need to scan low. I can place the scanner into this while moving the TriPod. No need to open and close the case every time you move. You may ask what this the masking tape for? Well I set the orientation of the scanner at the ZERO point - at this corner. Thereby being able to scan a sector with ease and not having to scan a full 360.
Thank you !
I hoped a solution to buy (at this moment, i don't have many time) but it's very good, and i take this on a corner for future.
Thank you again, your help is very precious
Vincent DENIS
Re: Elevated Tripod
Post by Vincent DENIS » Fri Jul 28, 2017 7:42 am
Hi again Nick!
I come back to you because in this holidays time i made your platinum and i mets a concern about the central screw.
Indeed i think it's a american screw and in france a have many dificulties to found it. Do you know the exact mesure of the screw and maybe a website were i can buy it?
Thank you very much
Formula1982
Full Name: Stephen Ferrari
Re: Elevated Tripod
Post by Formula1982 » Fri Jul 28, 2017 12:17 pm
Some images of myself about 6-7 years ago at Spa Francorchamps and Phillip Island race circuits, scanning from our very long legs. Putting a Scanstation 2 up there is not easy, working from a ladder!
Return to “Z+F”
