Faro Focus String Remote
- jcoco3
- Full Name: Jonathan Coco
- Company Details: Consultant
- Has thanked: 70 times
- Been thanked: 157 times
I am not proud of this one, but at least its a funny way to start off the new year Santa brought us(after we paid him) a new X330 and a Gitzo Giant. Only problem is we have to use wifi to start a scan, which uses much more battery.
youtu.be/
Ugly yet effective. Somewhere there is a Faro engineer shaking his head.
youtu.be/
- ddustin
- Full Name: David Dustin
- Been thanked: 11 times
Re: Faro Focus String Remote
You are without a doubt, the most creative person I know when it comes to any kind of a solution.
Hence the reason I refer to you as the "Mad Scientist".
David
David
- Country: Italy
- Has thanked: 15 times
- Been thanked: 53 times
Great solution!
But I'm missing a step.
Are you using zip ties for the contact? The Focus 120 display is capacitive and very picky. I tried an assortment of material (but not zip ties) to do something similar with no success.
Is the X330 display different or am I missing a key point of the touch process?
- rbrch
- I have made 60-70 posts
- Full Name: Roy Beukeveld
- Company Details: Emmtec Engineering
- Company Position Title: Mechanical Engineer
- Country: Netherlands
When you combine high tec with low tech, does this solution make it mid tech? Lol
We use a high tripod as well (faro 4.5m) but with the wifi option;)
I haven't noticed a significant increase in power usage though.
Anyway, nice to see creative solutions...
Kind regards,
Roy
Roy
- jcoco3
Unless I missed something a long time ago, all Focus scanners have a resistive touch screen, meaning they need pressure touch not capacitance. This is typical of devices that are used in outdoor environments where moisture or gloves may interfere. The slightly loose membrane over the LCD screen is a dead give away. To answer your question, yes it is just the end of the zip tie banging into the touch screenThe Focus 120 display is capacitive and very picky.
The wifi does drain a little more power, ultimately it can reduce the maximum number of scans you can capture from a single charge. Not that big of a problem for us now that we have many batteries and a dock charger, but it is still a hassle.
This method of touching the screen is still not the most efficient since it keeps the screen active draining the battery significantly also. I tried to set this up to push the start/stop hardware button instead of the screen button, but it required too much effort(I need to 3D print a bracket with a lever and cam). When making numerous scans at the same settings we have found that we can squeeze more scans out of a single charge, by setting the screen to dim in 15min and using only the hardware start/stop button which does not re-activate the screen. I kind-of wonder why the firmware doesn't just turn the screen off instead of dimming it. That would conserve even more "juice."
We have started recording how many additional scans after the low battery warning we can achieve from specific settings before the scanner goes dead, but the number varies with temperature and the age of the battery. We also are working on how many scans of a single setting that can be captured from a single charge, but that number has even more variables. There be another rule of thumb table or spreadsheet to make when I get bored.
- Country: Italy
You are right!jcoco3 wrote: all Focus scanners have a resistive touch screen
When I tried to operate the screen with gloves it didn't respond, so I assumed it was capacitive. Probably my gloves were too soft.
I can reconsider my remote control idea..
Thanks,
- ScottKarlins
- I have made 50-60 posts
- Full Name: Scott Karlins
- Company Details: Engineering Systems Inc.
- Company Position Title: Technology at Large
- Skype Name: ScottKarlins
Jonathan,
Great solution! I was using WiFi to start the scanner on my Gitzo Giant, but this is better indeed, less battery drain. I am already 3D printing a bracket for the Start/Stop button!
Scott Karlins
Technology at Large
FARO Certified Trainer
(678) 990-3280 ext. 6025 Fax: (678) 990-3285 Mobile: (770) 338-9946
http://engsys.com
Technology at Large
http://engsys.com
- jcoco3
Scott you are one step ahead of me now Zips ties work fine, but if I had a 3D printer I could print a more permanent solution that was removable without being destroyed.I am already 3D printing a bracket for the Start/Stop button!
- Full Name: Scott Page
- Has thanked: 206 times
- Been thanked: 78 times
Scott- I'll buy one too (another Gitzo Giant owner) if you will print a few extras.I am already 3D printing a bracket for the Start/Stop button!
~Scott
