Topography Survey
Discuss all Faro related issues here.
suggest101
Full Name: ANDY
Company Details: CLANCY
Company Position Title: CTO BOSS STRAITS
Country: INDONESIA
Topography Survey
Post by suggest101 » Mon Oct 29, 2012 4:43 am
Hi
Topography Survey for land reclamation has been offered to us through a local surveying company who would like to use our Faro 120 laser scanner. To date we have been involved in inspection related scanning services and do not come from a surveying back ground. Although I see a mobile mapping scanner as the best option but not the cheapest, we really would like to get involved in this one.
Any advice on this job would be welcome.
Andy
pollete
I have made 70-80 posts
Full Name: JOSE MARTINEZ RUBIO
Company Details: LFA-DAVAP
Company Position Title: Technical director
Country: Spain
Skype Name: josufet
Re: Topography Survey
Post by pollete » Mon Oct 29, 2012 8:27 am
I'd say this is not the kind of survey for any TLS. IMHO you should recommend another technology... my choice would be aerial phototogrammetric survey with UAV.
Regards
José Martínez Rubio
LFA-DAVAP Valladolid University
http://www3.uva.es/davap
MarkL
Full Name: Mark Lupton
Company Details: SEA
Skype Name: markl9999@yahoo.com
Post by MarkL » Mon Oct 29, 2012 12:36 pm
I think I'd have to agree with Jose and say some kind of aerial survey would be best. I don't see the FARO scanner as being very efficient for this particular job due to the number of setups you'd need. We've been using it for topo, but always in conjunction with conventional methods and only where it is useful, such as for buildings and hard surfaces. It looks like an interesting project, so it might be worth seeing why they specifically want to use your FARO.
suggest101
Full Name: ANDY
Country: INDONESIA
Post by suggest101 » Mon Oct 29, 2012 3:02 pm
Interesting...thanks for the input. I will be meeting with the client tomorrow.
tbwester
Full Name: Thad Wester
Company Details: WeWork
Post by tbwester » Mon Oct 29, 2012 3:33 pm
It really depends on the deliverable required.
If for some reason they were interested having a "point cloud" so they could extract other information, then maybe a mobile scanner would be a good idea.
This is a really large area for a ground based scanner - especially phased based.
Dave Andrews
I have made 90-100 posts
Full Name: Dave Andrews
Company Details: R.E. Warner Associates Inc.
Company Position Title: 3d Scanning Coordinator
Post by Dave Andrews » Mon Oct 29, 2012 4:49 pm
I would think using GPS and having the aerial photos as a background would be a good product, more efficient and by far cheaper.
DA
"The harder you work, the harder it is to surrender."
Woody Hayes
johnhalifax
Full Name: John Halifax
Company Details: Mining Surveys UK Ltd
Country: uk
Skype Name: john_halifax
Post by johnhalifax » Mon Oct 29, 2012 6:17 pm
Hi Andy,
You will struggle with your scanner.
UAV's are ok, great ortho-images, but you will only get a Digital Surface Model as opposed to a Digital Terrain Model which will be required for this type of project.
We have recently undertaken a project, similar to yours, where we used both a long range scanner, mounted on a 4 X 4, and a UAV. The UAV was used to produce really good ortho-images and ground levels in areas without vegetation. The scanner was used to scan any vertical faces and areas with vegetaion, which was filtered out later. A trimble R6 was used to fix the scanner location and the final scan data was used to fix ground control points for the UAV's images.
I think that this is the most efficient way to produce accurate topo surveys and DTM's.
As a company we are keen to show how well this works and would be happy to help you, we can provide both a top of the range scanner, best on the market for this type of project and also the best UAV on the market.
Give me a call if this is of interest. 01246 268444.
pollete
Country: Spain
Skype Name: josufet
Post by pollete » Tue Oct 30, 2012 8:06 am
johnhalifax wrote:Hi Andy,
Could you explain this further, please?
I'd also be thankful if you could describe a little your equipment and workflow with UAV imagery. Thanks
José Martínez Rubio
johnhalifax
Country: uk
Post by johnhalifax » Tue Oct 30, 2012 6:58 pm
Hi Jose,
The kit we use is a Riegl VZ-1000 with a Nikon D700 calibrated camera and on top of the camera is a Trimble R6 GPS receiver. The UAV is a Gatewing X100.
Firstly we create a site calibration with a scale factor of 1. We fix control points on and around the site using a base station and 2 additional receivers. The wgs84 data is processed using a network adjustment programme, this will give us accuracy of + or - 5mm. This is then uploaded to the survey controller and used to fix the location of each scan, but not the orientation.
The scanner is mounted on the roof of a 4 x 4, this stop go method of surveying is very fast. The range is set at the lowest range, for the VZ-1000, 450m. At this range setting the speed will be 122,000 points per second and a high resolution the scan will take 47 seconds. The GPS location can be recorded simultaneously. Targets set over the control points are scanned at various times these are used both to orientate the scans and verify the accuracy of the final data. Using this method, when colour is not required, we can complete 50 scans in 2 hours.
The ground control for the UAV are laid out and scanned.
Once the scan data has been collected we register the scan locations using Riscan Pro. Firstly we filter the data using an octree and deviation filter we then use a planer surface and a deviation filter. using the backsight method we register those scans that have a tie point. Those scans with only a GPS scan location are fixed using this location point and an approximate northing. These scans can be rotated using the modify scan location. When all scans positioned we use the Multi Station Adjustment routine, we lock location and orientation of those scans with a backsight and we lock only the location of all those scans without. This will then fix all scans within about 30mm (GPS error). We then run the MSA again, this time we unlock the location and orientation of all but one or two scans. We the check the results of the tie point scans (back sights on control points) against the site calibrated control to confirm the accuracy of the survey.
At this stage we can use the scanned ground control to process the images acquired by the UAV. Under normal circumstances there would be relatively few points for ground control however with the scan data any amount can be used to improve and check the accuracy of the Digital Surface Model produce by the UAV's data.
Once the scans are registered we can start to classify the data. We use Terrascan. We run a number of macros which classify, ground points, vegetation, buildings etc.
Ground points are then taken back into Riscan Pro where we produce a mesh. At this point we would extract breaklines if required. We can also out put ground contours, a grid of levels and sections etc.
We would also export the mesh as a BMP which can be used in LSS to drape over the Digital Terrain Model or as a background in AutoCad. The high resolution ortho-rectified image, acquired by the UAV, is also used in the same way in LSS and AutoCad.
For the features such as buildings, fences etc we use a classification routine in Terrascan to slice through at a known height above ground. This is then exported to Cad.
This workflow works well for certain sites but we would not be averse to using GPS or total stations, as well, where there are lots of service covers at ground level.
Also with the VZ-1000 range of 1.4km we would also mount the scanner on a tripod if site conditions suited.
If you would like to know more please feel free to give me a call, details on our web site www.miningsurveys.co.uk
Post by Jason Warren » Wed Oct 31, 2012 7:05 am
Hello John,
Thank you for your detailed post, much appreciated and do you have any screenshots you could upload?
Best regards,
#ThePowerofLSF
Return to “Faro”
