Deleting a door
Discuss FARO hardware here.
horrgakx
Full Name: Dave Wilson
Company Details: Nuclear industry
Company Position Title: Sub-PM
Deleting a door
Post by horrgakx »
I have a door which in one scan was closed and another scan was open. The result is 'most' of the door is in place.
No matter how accurate I try to be there's always some other data deleted, like parts of the floor for example.
I tried narrowing it down using the clipping box but the box is at a weird angle to the door so it's hard to narrow the data right down to only rhe parts I need to delete.
landmeterbeuckx
12
Full Name: Lieven Beuckx
Has thanked: 192 times
Been thanked: 574 times
Re: Deleting a door
Post by landmeterbeuckx »
horrgakx wrote: ↑Mon Jun 10, 2024 10:08 am I have a door which in one scan was closed and another scan was open. The result is 'most' of the door is in place.
I scan a lot with a closed door and open one. I never delete info on a door because the opening direction is often good to know for anyone using pointclouddata. I would leave it alone.
Deleting data is imho in Scene not very convenient and if i need to delete stuff i do it in recap (but in 95% of the time i leave it as is).
LSBbvba
Tel : +32477753126
www.lsbbvba.be
horrgakx
Re: Deleting a door
Post by horrgakx »
I understand about the door direction. But the door (or any parts of it) are closed on the scan and it just looks weird.
I get what you're saying about Scene not being good for cleaning up scans but maybe it's better to leave it for the client to deal with 😁
Justin Richards
3
Full Name: JUSTIN RICHARDS
Company Details: Tribrach Solutions
Has thanked: 38 times
Been thanked: 56 times
Re: Deleting a door
Post by Justin Richards »
if it's just one scan, open the single scan in 3D view and use selection tool to delete it.(the one of right is just open for illustration)
If it's a lot of scans, turn off visibility for the scans you don't want to remove points from before doing the cleanup, then turn them back on after you clean it up
horrgakx
Re: Deleting a door
Post by horrgakx »
Thanks! Did you use the Polygon tool to select the door?
Justin Richards
3
Re: Deleting a door
horrgakx wrote: ↑Mon Jun 10, 2024 2:34 pm Thanks! Did you use the Polygon tool to select the door?
np, it was the polygon tool
Return to β€œFARO”
