Battery stuck on Faro Focus3D X 330
Discuss FARO hardware here.
VincentVerhoeven
Full Name: Vincent Verhoeven
Company Details: Tampere University
Company Position Title: PhD student
Country: Finland
Post by VincentVerhoeven »
Hello everyone. I have a bit of an awkward problem with the scanner I was borrowing at work. I recharged the battery and went to put it back in, but it wouldn't go further than ~90% of the way there and also doesn't go back out (regardless of whether the eject button is pushed up or not whilst pushing/pulling on it).
Does anyone know what the solution might be and what I may have done wrong?
Thank you for your time.
JFlammVDC
6
Full Name: Jason Flamm
Company Details: PARIC Corporation
Company Position Title: VDC Survey Manager
Has thanked: 16 times
Been thanked: 14 times
Re: Battery stuck on Faro Focus3D X 330
Post by JFlammVDC »
I think you may have the battery 180 degrees off. Hopefully you can get it extracted!
PLS MO, AR, MS
Part 107 UAS Pilot
Dave Andrews
11
Full Name: Dave Andrews
Company Details: R.E. Warner Associates Inc.
Company Position Title: 3d Scanning Coordinator
Been thanked: 22 times
Post by Dave Andrews »
A large pair of channel locks should do the trick. Don't apply to much pressure.
Woody Hayes
VincentVerhoeven
Country: Finland
Well that was a bit of a dumb mistake. Figured the sticker on it would be legible the right way up.
Tried the channel lock pliers, but it wasn't sticking out far enough to get a good grip on the battery.
Fortunately I also brought some flat head screwdrivers and I could push it out by pressing against the little cut-out on the top of the battery.
Return to “FARO”
