Importing control points in scene - help please
Discuss FARO hardware here.
Augusto 3D
7
Full Name: C-Augusto
Company Details: 3d scanning
Company Position Title: USA
Country: US
Has thanked: 44 times
Post by Augusto 3D »
Hi everyone, I have some questions about what happens on the backend in Scene when we import control points.
Once we import the points file we are asked if we want to apply the control at the cluster or project level, however, regardless of the selection, the References folder appears on the main root of the project. This is confusing.
I gather that by making the project or cluster selection the correspondences are searched within the cluster or whole project (am I correct?)
if I open a project that someone else worked on, how can I identify if the control is meant to be applied at the project or cluster level?
the second question I have:
Why does the first control point name get changed to have an 'i' ? Does this mean anything?
Thank you
tengui
I have made 60-70 posts
6
Full Name: NEDELEC Tanguy
Company Details: Prigent et Associes
Has thanked: 3 times
Been thanked: 7 times
Re: Importing control points in scene - help please
Post by tengui »
From the help PDF : "If external references are available, the Reference folder of the cluster is used first. If not, the Reference folder of the next available higher leveled cluster is used."
Depending on your choice at import, the reference folder isn't created at the same place, at least on my side:
For the "i_" stuff, are you sure that's not how the point is named in your imported CSV/TXT? I don't see this behavior personnally.
landmeterbeuckx
10
Full Name: Lieven Beuckx
Has thanked: 107 times
Been thanked: 336 times
Post by landmeterbeuckx »
Augusto 3D wrote: Wed Jun 29, 2022 8:28 pm Hi everyone, I have some questions about what happens on the backend in Scene when we import control points.
Thank you
Check this video i made a few years ago
https://www.youtube.com/watch?v=K8Wf9gwu0ZU&t=223s
LSBbvba
Tel : +32477753126
www.lsbbvba.be
Augusto 3D
7
Country: US
tengui wrote: Thu Jun 30, 2022 12:57 pm Hello,
Depending on your choice at import, the reference folder isn't created at the same place, at least on my side: RefFolder.png
The "i" is not in my CVS file. I just cheked again.
hard to explain it, but I think it makes sense. When you run the registration it is going to look at the clusters first - like from the inside - out.
Return to “FARO”
