Faro 2go
- Full Name: Giorgi Mikadze
- Company Details: Engineering Idea
- Company Position Title: Lidar operator
- Country: Georgia
- Skype Name: miqgio
Faro 2go
Hi guys,
Does anyone knows how to insert 2go project back to scene or export panorama images?
Thanks in advance.
Thanks in advance.
- Leandre Robitaille
- Company Details: Cima+
- Has thanked: 61 times
- Been thanked: 246 times
- landmeterbeuckx
- Full Name: Lieven Beuckx
- Country: Belgium
- Has thanked: 183 times
- Been thanked: 548 times
Re: Faro 2go
This is not a problem with aro webshare only.
Riscan produces Ripano webviewer. Images in Riscan are full panorama but transfered to Ripano in viewing mode it is a pano but in the fomders these are all seperate images (hundreds per pano).
Think Leica webviewer works the same.
Only option is to ask the people who did the original project to export from Scene
- I have made 30-40 posts
- Full Name: Martin Heide
- Company Position Title: Senior 3D Software Engineer
- Been thanked: 3 times
Re: Faro 2go
Hi Giorgi,
The panorama images of a SCENE 2go project can be found in the following place in the folder structure:
YOUR_2GO_FOLDER\source\s2go-data\project\PROJECT_NAME\scans
See attached screenshot.
Depending on the scan and the SCENE 2go export settings that you had chosen, the panorama images are available in intensity and/or color, and with a resolution of up to 8192x4096.
Each panorama image has the color mode and image width in the file name, e.g. "2de7927c-5337-446a-b879-364e010b685a-color-4096.jpg".
You can re-import panorama images to the SCENE project as explained here, under "Importing an Edited Image":
https://knowledge.faro.com/Software/FAR ... s_in_SCENE
Or watch the tutorial video: https://knowledge.faro.com/Software/FAR ... ng_Objects
Best regards,
Martin Heide
Best regards,
Martin Heide
- Country: Georgia
Re: Faro 2go
Hi martin,
Thanks a lot, I thought I looked every folder but now I see I didn't.
heidem wrote: ↑Thu Dec 02, 2021 7:08 am Hi Giorgi,
Best regards,
Martin Heide
- Rvillarreal2824
- Full Name: Ruben Villarreal
- Company Details: El Paso Police Department
- Company Position Title: CCSI_Police Officer
Re: Faro 2go
Hello All,
Not to step on anyone's feet but yes you can import/export Pano photos. This is great if you have a scan that is either over or under exposed. Yu can export the Pano image and then "enhance' it on Photoshop or Light Room (or any program for that matter. Then you import it back to your scans and register it. It helps and will/might make your diagram look better by correcting the "bad colored" scans...you can also do this from the Structure Tree Directly which I think is best done there since you can see which scan needs 'photoshopping'...hopefully my screen shot is attached
- Rvillarreal2824
Re: Faro 2go
...on that same note, this is also great when you have someone in your scans and cannot delete that scan. Obviously when the end user receives your Scene2Go, that person in the picture will be seen. You can export the Pano, "blurr" them out or change what needs to be then import the photo back. When they open a quick/pano view, you should see the blurred photo, in this case like this detective eating pizza at a Homicide
Also of course be prepared to explain the process in court and why it was done...
- TommyMaddox
- Company Details: ONSITE3D
- Has thanked: 67 times
- Been thanked: 130 times
Re: Faro 2go
I have made a workflow to bring the full resolution Nikon D850 DSLR Riegl Panoramas (sans stitching blur) into FARO WebShare cloud, but it isn't a fun or easy process presentlylandmeterbeuckx wrote: ↑Wed Dec 01, 2021 2:26 pm This is not a problem with aro webshare only.
- landmeterbeuckx
- Country: Belgium
Re: Faro 2go
Why would you want to do that? Give them a Ripano instead i would suggestTommyMaddox wrote: ↑Fri Dec 03, 2021 8:26 pmI have made a workflow to bring the full resolution Nikon D850 DSLR Riegl Panoramas (sans stitching blur) into FARO WebShare cloud, but it isn't a fun or easy process presentlylandmeterbeuckx wrote: ↑Wed Dec 01, 2021 2:26 pm This is not a problem with aro webshare only.
- TommyMaddox
Re: Faro 2go
Because our clients use WebShare Cloud. And that's the platform I'm pushing data to.
And if you don't get the panos in there, you get terrible PTX views.
