The new Panorama camera for the FARO S350 demo
Discuss FARO hardware here.
LPaulCook
8
Full Name: L Paul Cook
Has thanked: 47 times
Been thanked: 44 times
Post by LPaulCook »
I recently purchased the new Panorama Camera and mounting bracket available now for my FARO FOCUS S350 scanner.
Only yesterday did the new version of SCENE come out that can now process the Pano Camera images and map the color on the scans.
The collection time for color now is down to 15 seconds for one 360° image or 30 seconds for two. Why two you ask, taking two masks out the top of S350 scanner body in the image. If you just take one image you will see the top of the scanner in each scan.
The camera being higher than the mirror is correct by one calibration scan you take at the beginning of reach job. This corrects for parallax on objects at a little distance from the scanner. Object very close will have a slight grey line around the bottom of the object where the color camera missed what the scanner captured.
All in all I'm very happy with the results.
The cost was about $1,600 USD total. Well worth it if you want color which I sometimes do.
I made this 2 minute video today to demonstrate the results.
We used two scanners for this job, one with the Pano Camera and one without. The camera path used to make this video is around the scan positions with the Pano Camera only. You will note the gray scale points made by the other scanner in this point cloud.
https://vimeo.com/650062634
L. Paul Cook, PLS
www.LPC3D.com
ProCro
4
Full Name: Nino Skupnjak
Company Details: SKIMI64
Company Position Title: procurator
Country: Croatia
Has thanked: 7 times
Been thanked: 30 times
Re: The new Panorama camera for the FARO S350 demo
Post by ProCro »
Don't get me wrong, but this result looks very bed. I have X130 and with internal cam i have 10x better results. Are you sure that you did everything allright?
This is sample from my X130
other samples from panocam that we can find on youtube looks way better...
landmeterbeuckx
11
Full Name: Lieven Beuckx
Has thanked: 183 times
Been thanked: 548 times
Post by landmeterbeuckx »
Looks awful indeed. Or did something go wrong with the rendering of the video?
LSBbvba
Tel : +32477753126
www.lsbbvba.be
LPaulCook
8
Post by LPaulCook »
Half the points are not color as one scanner had the pano camera and the other was just grey scale.
I will make a new video with just the color scan points to see the difference.... but not today.... Thanksgiving Day!
L. Paul Cook, PLS
www.LPC3D.com
LPaulCook
8
Post by LPaulCook »
Okay, I agree that the first video did not look all that good due to half the point cloud was produced with a non-color scanner and the other half using the new 360 Panorama top mounted color camera.
This new video only uses the colored point cloud data.
See it here: https://vimeo.com/650150449
L. Paul Cook, PLS
www.LPC3D.com
landmeterbeuckx
11
Much better Paul. I don't use a theta z with my tx5 because this doesn't work but i use a theta z solo and am very pleased with the pictures. For 900€ it produces good pics for what i need them for.
Of course it's not the best photoquality but much better then that bloody istar i once had. Costed me 5x as much, bad results and noone at Nctech seemed to care about this product anymore so it died a slow dead. I sold mine to someone abroad.
LSBbvba
Tel : +32477753126
www.lsbbvba.be
INV_Scanning
4
Full Name: Sebastian Winkler
Company Details: INVERS Industrievermessung und Systeme
Has thanked: 5 times
Been thanked: 6 times
Post by INV_Scanning »
I like the combination with the Theta Z1, even if it doesn´t fit to our main application topics (parallax in near range won´t work for us). So I asked myself if there is a way to colourize the scans "manually" by the Panos, like Istar etc. did.
badam
2
Full Name: Adam Berta
Country: Hungary
Has thanked: 51 times
Been thanked: 297 times
Post by badam »
INV_Scanning wrote: Tue Nov 30, 2021 10:56 am I like the combination with the Theta Z1, even if it doesn´t fit to our main application topics (parallax in near range won´t work for us). So I asked myself if there is a way to colourize the scans "manually" by the Panos, like Istar etc. did.
As far as i know there is no opensource library which can write/handle data as structured point cloud because that is what is needed to colorize a scan. you need to now the exact location of each point relative to the scanner as a pixel like a radial coordinate system. that way you would be able to write a program which handle the colorisation pixel by pixel.
jsteinert
4
Full Name: joshua steinert
Company Details: pb2 architecture + engineering
Company Position Title: Graphics Manager
Has thanked: 20 times
Been thanked: 12 times
Post by jsteinert »
Would the panorama camera addon work with the Faro Swift system? Can the Theta take a located photo without TLS scanning?
This could be beneficial with some of our restaurant clients. When I scan the kitchen, sometimes we need a pano 5-10 feet apart to measure a vent hood and a sink next to it. Many prefer to do measuring within the pano view.
Cumbersome to do another scan 10' down, and occlusion may not be a problem if the swift system is mobile scanning anyway.
Amplify that by 100 locations on a site and the time to do a TLS scan vs a pano capture matters.
Return to “FARO”
