Uses a Ricoh Theta Z1 which only has a 6720x3360 resolution.
It's great for colouring point clouds quickly (quicker than the higher res internal camera), but the pano quality is much lower than the internal camera.
Sorry, could you answer one of my previous questions? I quoted your answer but as I posted 2 answers after that, it is a posibility that you didn`t see it.Leandre Robitaille wrote: ↑Mon Aug 02, 2021 3:09 am RJ I am suprised you are bringing the RTC in this convo as it is common knowledge that the picture quality is timefold worst on the RTC compared to a Faro scanner. I am sure they will get there tough, I feel if they release a RTC scanner with actually good pictures and a decent compensator in it they would have the king of all scanners. But as of now even with the so called "HDR" they do, they are no where near the picture results a Faro scanner gives.
