Post processing Software for Faro S 3D Scanner
Peter Blake
Full Name: Peter Robert Blake
Company Details: PB INDUSTRIAL DESIGN
Re: Post processing Software for Faro S 3D Scanner
Post by Peter Blake »
DELETED
jedfrechette
Full Name: Jed Frechette
Company Details: Lidar Guys
Has thanked: 4 times
Been thanked: 22 times
Post by jedfrechette »
Peter Blake wrote:
Mon Mar 23, 2020 7:40 am
The support for FARO Scene in Australia is appalling. Even with a FARO scanner try another software. Instead of improving the base program "SCENE", every feature you need is sold as a stupid separate "rip off" program.
Well as long as I've been using it does seem like their software development roadmap has been:
1. Make a HTML wizard
2. Acquire other companies.
So I guess that sentiment is understandable.
SAttaya
Full Name: Steve Attaya
Company Details: Geocent
Has thanked: 8 times
Post by SAttaya »
jedfrechette wrote:
Thu Mar 19, 2020 2:59 pm
Scene is fine for what it is, very basic registration and data interrogation. It is pretty fast for ingesting and roughly aligning scans, however, depending on your tolerances and requirements it may not offer enough control over the process. More than a few of us use it as a preprocessing step before taking the scans in to another software to finish alignments. ...
There are a few software options out there that will work, so just because you have Faro hardware don't feel like you need to use their software if it doesn't do what you need.
Jed,
Would you (and/or others) recommend/specify what you use after scene to finish alignments:
* designx
* cyclone (register)
* recap
* other????
jashby
Full Name: John
Company Details: Ashby
Country: US
Post by jashby »
The best registration (for bigger environments than a single room) I’ve ever got out of Faro Scene was about 6mm for an interior. And even then there were some walls that were incorrectly aligned. The same Faro data run through Cyclone got 2mm.
I no longer use Scene.
Scene is also only really good if your scans auto align, and if you ever scanned a slightly symmetrical environment you’ll find Scene just throws everything on top of each other. Useless.
While there is more manual registration with Cyclone it’s a really fast workflow once you assign some (sane) hotkeys.
I registered 70 scans manually in top down view in Cyclone in a little over 2 hours. Last time I tried to do the same in Scene it took about a week.
J.
jedfrechette
SAttaya wrote:
Wed Mar 25, 2020 6:44 pm
PolyWorks. After all this time it's still the most powerful. It has it's share of issues though.
jashby wrote:
Wed Mar 25, 2020 7:06 pm
I completely agree.
Our informal rule is that if you've spent more than 15 minutes trying to fix a broken alignment in SCENE it's time to get the data out of SCENE and into software where there is more control. This actually makes SCENE a good preprocessor for PolyWorks, SCENE does the easy part of the alignment quickly and PolyWorks gives us the tools to verify the alignment, improve it, and when necessary salvage even the most poorly scanned projects.
That's an expensive and complex process to maintain though and one I'm actively looking at simplifying. I'd love to do everything in SCENE, but unless it's tools and UI improve significantly I don't anticipate that being feasible for us. We've already reduced the number of SCENE seats we keep under maintenance and eventually will probably end up migrating to either Cyclone or RealWorks.
Return to “FARO”
