Post processing Software for Faro S 3D Scanner
Abdelkareem
Full Name: Abd Elkareem Mohamed
Company Details: 3DME
Country: United Arab Emirates
Post by Abdelkareem »
Hi Guys
Is there are any alternatives to process the point cloud getting from the FAro Scanner or i only should use Faro Scene Software?
brian715
Full Name: Brian Boehmer
Has thanked: 12 times
Been thanked: 5 times
Re: Post processing Software for Faro S 3D Scanner
Post by brian715 »
I think scene does a good job and use it daily. However you can use Cyclone as well to process and register FLS files.
Scott
Full Name: Scott Page
Has thanked: 58 times
Been thanked: 20 times
Post by Scott »
brian715 wrote: Tue Mar 17, 2020 12:13 pm I think scene does a good job and use it daily. However you can use Cyclone as well to process and register FLS files.
+ 1 --Use Scene, it works!
Mind
Full Name: Mindaugas Juska
Company Details: Elipsus
Country: Lithuania
Skype Name: mind.juska
Post by Mind »
If you are using Faro S series laser scanner then go with Scene or Realworks because both of them can read and apply Faro S or X series inclinometer data. Cyclone can no do this with Faro scanners so your scans will be unleveled. However, I know there is walkaround with Cyclone for this but for this type of scanner I would choose Scene or Realworks software.
Elipsus 3D laser scanning
Mindaugas Juška
+370 679 39354
fobos8
I have made 100> posts
Full Name: Andrew
Company Details: Medina Surveys
Country: Uk
Been thanked: 9 times
Post by fobos8 »
Mind wrote: Wed Mar 18, 2020 7:54 am If you are using Faro S series laser scanner then go with Scene or Realworks because both of them can read and apply Faro S or X series inclinometer data. Cyclone can no do this with Faro scanners so your scans will be unleveled.
I understand that this is no longer true and that the latest release of Cyclone CAN read Faro inclinometer data. I haven't seen it for myself but have had it confirmed by SCCS in the UK.
VXGrid
Full Name: Martin Graner
Has thanked: 23 times
Been thanked: 24 times
Post by VXGrid »
Abdelkareem wrote: Tue Mar 17, 2020 11:42 am Hi Guys
Since you are a Faro distributor and your main selling point is to sell the scanner (the software is just a nice bonus for you), you should look at something which is very easy to handle and will give your customer a complete workflow, rather than leaving him with the point cloud.
With PointCab you can show the registration done in Scene or in PointCab itself (when done in Scene you can import the lsprj file into PointCab) and wrap your presentation up by generating some layouts/sections/linework and open that via dwg/dxf in the CAD software of your customer.
If they are using Autodesk products you could export the point cloud from Scene as a rcp file, so they can load that into Autocad/ReCap.
msvensen
Full Name: Mattias Svensen
Company Details: Faro Technologies
Company Position Title: Area AM
Country: Sweden
Post by msvensen »
Hi!
We nowadays have the ability to offer 3-months and 12-months subscription of Faro SCENE. Its a great way to optimize and ensure low-cost software if you have a short-term project and would like to have the software as an little overhead cost. If you are using Focus-scanners the advantage and quality will be aligned in a best possible way using SCENE.
https://www.faro.com/products/construct ... aro-scene/
PS: We also offer subscription-based licenses on most of our softwares like BuildIT! and As Built softwares.
Laser Scan Slawny
Full Name: Brent Slawnikowski
Company Position Title: Senior Account Manager
Post by Laser Scan Slawny »
Using SCENE gives you the best advantage especially if your using onsite registration with your tablet or laptop. This is the fastest workflow in the industry as it allows you to fully process and register your scans on the fly and leave the site with a fully ready data set. Depending on where your client takes the data, they can directly export to Recap or Microstation (.pod) and begin extraction. If they are doing analysis they can open the Scene project file directly into BuildIT Construction.
jedfrechette
Full Name: Jed Frechette
Company Details: Lidar Guys
Has thanked: 8 times
Been thanked: 38 times
Post by jedfrechette »
I see the Faro reps are out in full force this morning. ;)
To get more helpful answers you might need to expand a little on what you mean by post-processing as that can mean a lot of different things to different people.
Scene is fine for what it is, very basic registration and data interrogation. It is pretty fast for ingesting and roughly aligning scans, however, depending on your tolerances and requirements it may not offer enough control over the process. More than a few of us use it as a preprocessing step before taking the scans in to another software to finish alignments. Admittedly, this approach is much less appealing now that Faro doesn't include a license with their scanners.
There are a few software options out there that will work, so just because you have Faro hardware don't feel like you need to use their software if it doesn't do what you need.
JFlammVDC
Full Name: Jason Flamm
Company Details: Paric Corporation
Company Position Title: VDC Survey Manager
Has thanked: 4 times
Post by JFlammVDC »
Laser Scan Slawny wrote: Thu Mar 19, 2020 1:27 pm
I can attest to this. I love Rithm and BuildIT.
Also, not sure who your client is or what your deliverable is going to be but with Scene you can add on a FARO Webshare-Cloud subscription and that is an absolute game changer right now in my company.
Return to “FARO”
